Air Filter question - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-22-2012, 06:12 PM Thread Starter
Date registered: Aug 2011
Vehicle: 2012 GLK 2013 SLK
Air Filter question
What is the difference between;
Replace engine air>cleaner insert Engines 272, 273 AP09.10>P>0980TS
which is listed as service 2 every 52000 miles or 4 years
and
Replace combination filter AP83.00>P>8384T
which is service 3 every 26000 miles or 2 years?
This from the MB Service Sheet for 2008 W211
thanks
Searching for the perfect W113
2013 SLK 350, had to have one again
2012 GLK, yes boring, but fun to drive
2008.5 Nissan Titan SE King Cab, for the heavy stuff
2005 SLK 350, gone and missed
Oak Forest, Houston TX, current residence
wine buyer is offline
post #2 of 7 (permalink) Old 06-22-2012, 06:25 PM
Tommyin Cbille's Avatar
Date registered: Jan 2012
Vehicle: 2012 E350 4Matic Wagon P2 Lane Tracking Driver Assit. Heated/Ventilated/Multicontour*/Leather seats
Quoted: 4 Post(s)
52000 on the main air filters (for engine air)
26000 on the combination filter (for cabin air)
Just changed mine yesterday (104K). Cabin filter still looked new. The main air filters hand a handful of debris in them. Last changed around 52k. I'll check the mains next time the combo filter is due for service. 52k is to long without checking them.
I used Mann filters I ordered from Amazon. About $50 for all 3 filters.
Tommyin Cbille is offline
post #3 of 7 (permalink) Old 06-22-2012, 08:34 PM
~BANNED~
Date registered: Jun 2012
the 272 and 273 filter is the engine air filter. the service of 52k mi is wayyy to long. they should be changed every 20k. the other filter is your cabin air filter for your climate control. it should be changed every year.. thats the bottom line...
peavysonic is offline
post #4 of 7 (permalink) Old 06-22-2012, 08:47 PM Thread Starter
Thanks for the info, just wished they called it a cabin filter like everyone else. And I will be checking these with every oil change
post #5 of 7 (permalink) Old 06-25-2012, 05:12 AM
Date registered: Aug 2009
Vehicle: 2007 CLK 550 , 2005 E320 CDI, 2003 SLK32, 2005 SLK 55
Quoted: 2 Post(s)
52,000 miles for an air filter is the correct interval. You are actually doing your engine harm by replacing them at 20,000. A filter is more efficient when half full of contaminants than when new.
Homebrewer is offline
post #6 of 7 (permalink) Old 06-25-2012, 06:01 AM
Date registered: Jul 2005
Quoted: 1010 Post(s)
peavysonic claims he is a dealer tech. No reason to accuse him of not being truthful, but some of the
posts he made about things that have already been well established about the W211 care and upkeep
were horrible. The 52k mile interval is perfectly safe and is best for the engine.
Each cylinder bank gets its own filter fed by independent intakes. The filtration surface area far exceeds
the engines need for air at full throttle on the 6 and 8 cylinder engines.
Posts like that are bad advice, just like the posts where members say they just do an oil change every
3000-5000 miles. That causes more wear than the 10000 mile interval due to the large oil capacity
and the detergents just keep washing away the protection in the oil until at least 3000 miles is used
with a MB spec oil like the Mobile 1 and other MB spec oils.
Over maintaining can be more harmful than sticking to the vehicle's factory service intervals.
The only area that has changed is the transmission and the differential. If it is 4matic also the front
diff and transfer case. In those drive line components the 2-3 year/40k mile changes will protect and
and add longevity to the components as long as the proper fluids are used.
Noodles is offline
post #7 of 7 (permalink) Old 06-25-2012, 06:36 AM
Quoted: 2 Post(s)
When I was maintaining generators in Iraq, we never had air filters for some of the generator models. We would just blow them out with low pressure compressed air and put them back in. I saw Caterpiller gen sets with over 10,000 hours that never had an air filter replacement. I would not have believed it had I not seen it with my own eyes. Not recommending that anyone do this, but based on my experience some people do over-maintain their vehicles.
