What's the best way to lift the car for working under? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-30-2012, 11:24 AM Thread Starter
Date registered: Sep 2009
Vehicle: 2006 E350 4MATIC
Always maintained my car at the dealer, but recently switched to DIY with success.
Many jobs require getting under the car, e.g., replacing transmission filter and fluid, replacing fuel filter, etc., on the W211, so wondering what's the best/safe tool for raising the car to work under it safely without breaking the bank?
For example, I saw some 3 Ton Craftsman Jack Stands at Sears for ~$30/each.
Please let me know from your experience the best options.
Thanks!
[B][FONT="Arial Black"][SIZE="4"]2006 E350 4Matic Sedan
AQMBE350 is offline
post #2 of 3 (permalink) Old 05-30-2012, 03:38 PM
Date registered: Sep 2008
Vehicle: 2006 Merc E320 cdi
Quoted: 47 Post(s)
Thanks!
Well, you definitely want to use jack stands and even ramps if possible..
FWIW, I have changed my oil, fuel filter, serpentine belt, and many other things just from the top..
aeubank is offline
post #3 of 3 (permalink) Old 05-30-2012, 03:52 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
A lift is the absolute best way to work under the car safely.
If you have to be under it, the more wheels you can leave on a solid surface, the better. A car on four jackstands isn't awfully stable. If you have to go that route, build some cribs to stack in there as a fail-safe, just in case.
BTW, the stands at Sears are fine, but I think that price is per pair. If you can wait for a sale, they often put those in a package deal with a floor jack and a cheap creeper for $110 or so.
That said, test your jackstand's release pressure. Put it in place with the handle facing out, let the car rest on it (you only want the tire barely off the ground) and then see if you can lift up the handle. If you can, that means you could inadvertently drop the stand if you kicked it, etc.
There is an excellent thread discussing this at Peach Parts: OT: but always on topic... secure raised vehicles! - PeachParts Mercedes ShopForum
Even on a lift, you have to think about what you're doing, too. I don't know the outcome of this incident, or what the guy was trying to do, but I hope he survived without serious injury to work another day.
Good luck.
Check Codes is offline
    Cab Lift/suspension lift or not?? normalbloke Unimog 5 02-24-2010 10:15 AM
    Pre face lift/post face lift question tommyb2b W140 S-Class 2 12-07-2008 11:46 AM
    Replace pre-face lift seats with post-face lift Jonas_Gothenburg R170 SLK-Class 4 05-28-2006 05:42 PM
    Exchanging pre-face lift door handles with post-face lift ones... Alan (Chicago) R170 SLK-Class 3 05-02-2003 02:01 PM
    Pre face lift vs. Post face lift... Alan R170 SLK-Class 4 12-14-2001 08:05 PM
