"brake service" warning reset - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 07-10-2011, 12:13 PM Thread Starter
515
Date registered: Oct 2007
Vehicle: 04 E320 4-MATIC WAGON
Hi all,
Done the search, read the responses--seems like a variety of opinions. Help. Got the non-red "BRAKE service brake visit workshop" warning. Replaced rear pads--front left pad had cut the sensor wire, but there is still LOTS of pad left so, yes, I just cut and shorted the 2 wires--thinking it would fool the car into thinking it has new pads then wait for the right front to go to replace pads. So, right now I have the 3 sensors (2 front and right rear) sending the computer "all is swell' signals. Now the dash indicator still has not cleared. I have actuated the brakes several times to pump up the system. SBC making all the right noises. Finally, my question. Should the warning clear itself once the sensors are replaced or does it need to still be reset be STAR or is there a way to reset myself? I noted some posts regarding pedal cycles exceeding a preset amount and giving a warning but I did have a bad sensor, so I am making the leap this is waht initiated this warning.
Thanks, all knowing MB wrenchers!
Larry
515 is offline
post #2 of 19 (permalink) Old 07-10-2011, 12:47 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Originally Posted by 515 View Post
Hi all,
Larry
The sensor is a "broken wire" sensor, it must be replaced to work. You may have twisted them together, but it does not work that way.
Mercedes mechanic is offline
post #3 of 19 (permalink) Old 07-10-2011, 01:35 PM
Roadking999's Avatar
Date registered: Apr 2008
Vehicle: E350 4M 06
Quoted: 6 Post(s)
Actually shorting the wires does work, the trick is to remove the 2nd layer of insulation before you solder them together. After you remove the outside cover, the wire looks bare but in reality it is still covered by a translucent layer of insulation, if you apply a soldering iron to it it will melt away and you will be able to solder the 2 ends, and your brake wear warning will disappear. Check the connection with a resistance meter at the connector end.
I only did this on the 1/2 life sensor, I do not recommend doing this on the 1/4 life sensors.
There is nothing you can do to reset the dash error, all sensors need to have a continious circuit for it to disappear.
Roadking999 is offline
post #4 of 19 (permalink) Old 07-10-2011, 04:02 PM Thread Starter
515
yeah, I thought it should work. I did go through the 2 layers of insulation, soldered, then verified continuity with a multi-meter. So, lets assume I have 3 happy sensors, properly plugged in to the correct spot. Any ideas why the warning will not go away?
Thanks
515 is offline
post #5 of 19 (permalink) Old 07-10-2011, 07:54 PM
Vehicle: E350 4M 06
Quoted: 6 Post(s)
Did you disconnect the SBC before you worked on your brakes? I read somewhere on this forum that it takes "several cycles" for the message to disappear.
Also, (at least on my car), sensor related messages always have the word "Wear" in them, other brake messages may be referring to the SBC unit it self or other brake components.
post #6 of 19 (permalink) Old 07-11-2011, 08:04 AM Thread Starter
515
I did disconnect the SBC--pulled the plug at the unit. As the only sensor that was really worn to breaking the wire was the left front--the early 50% warning--would that trigger this warning? I read in some posts about a "+" warning if the 50% wears. Where does that show?
I will put some miles on it to see if it clears, but if not, any other ideas before I surrender the car to MB? (they will LOVE my shorted sensor!)
515 is offline
post #7 of 19 (permalink) Old 07-11-2011, 08:15 AM
SPVFD47's Avatar
Date registered: Dec 2007
Vehicle: 1985 300D - 1997 E320 - 2004 E55 - 2007 ML320
Quoted: 14 Post(s)
Send a message via AIM to SPVFD47 Send a message via Yahoo to SPVFD47
I had the service brake visit workshop error appear on my 04 E55 when I bought it from a colleague. It wasn't there 2 weeks prior when I test drove it. Between that time the previous owner had the brakes done by an indie shop. He said that the shop didn't have the white left front sensor in stock and that was was what was propbably causing the message to pop up.
I talked to a MB tech that I know and he said theres only really only 2 causes on the early 211's that can cause it. The SBC and the brake light switch. I bought it the stealership and it was the SBC. "Service life exceed". MB replaced and flushed the brakes free of charge. The SBC has a 10 year warranty on it. Also the tech told me that the front left sensor will not pop a code or a warning in the cluster. The front left sensor is white sensor that is a 50% percent wear indicator. It only will show up on a SDS to tell the tech that at the next service the pads will probably need replacing. He said his service center cuts the wires, twists them and re-inserts the plug after sealing it to prevent corroision. The other 3 sensors will give you the brake wear warning.
I told the tech that the brakes were also just done before brining it to get checked out. He said the brake job wouldn't have caused the SBC to go and unless the indie shop had a SDS they wouldn't know if the SBC was bad. Just my luck that the SBC went at the time. He said he's changed plenty of them. All you have to do is take it to the dealer saying the brake service - visit workshop message is on the cluster and they will diagnose it. The message is also constantly on. If the SDS says the SBC is exceed its lifetime you don't have to pay for the diagnostic fee and the work is under the warranty. I don't see a difference at all after changing the SBC.
Just my 2 cents.
Doug
1985 300D
1997 E320
2004 E55
2007 ML320 4Matic
SPVFD47 is offline
post #8 of 19 (permalink) Old 07-11-2011, 08:24 AM Thread Starter
515
Thanks--from my reading and you post that is what I am thinking is going on. Did they tell you they reset the SBC or replaced it? And all I read says it should be free, even if I am not the original owner. True?
Thanks.
Larry
515 is offline
post #9 of 19 (permalink) Old 07-11-2011, 08:29 AM
SPVFD47's Avatar
Quoted: 14 Post(s)
Replaced it. Once it goes, it goes. There's no resetting. Hence why MB got rid of the whole set up. I'm trying to find out if the new one is now warrantied for 10 years.
Doug
1985 300D
1997 E320
2004 E55
2007 ML320 4Matic
SPVFD47 is offline
post #10 of 19 (permalink) Old 07-17-2011, 10:45 AM
Date registered: Jul 2011
I had the same problem and the dealer told me it was a bad SBC unit. Good thing mine was still under warranty because that unit goes for $4000
NormE320 is offline
    2002 CL500 Reset "Brake Lining" "Visit Workshop" warning on dash? jcarlosfox C215 CL-Class 1 01-06-2010 07:27 PM
    How to reset "Check Tire Pressure" warning? ct_r500 W251 R-Class 7 08-31-2009 11:07 PM
    Time for "A" service warning reset??? tozlakes W203 C32 AMG, C55 AMG 3 09-16-2008 05:09 PM
    "Service B" warning reset? funnyguy1 R230 SL-Class 5 09-05-2008 04:14 PM
    HELP...how to reset "service warning" OJwerks R170 SLK-Class 3 11-26-2006 03:23 PM
