rough idle at start, then dies.....help!!! - Mercedes-Benz Forum
post #1 of 45 (permalink) Old 07-02-2011, 03:22 PM Thread Starter
dacollector's Avatar
Date registered: Sep 2005
Unhappy rough idle at start, then dies.....help!!!
ok, so i am backing up into my garage, i stop the car. noticed that i needed to go back a little more, so i started the car, as the car starts, i am pressing the brake and ingage the shifter reverse,i release the brake to go backward, there is a slight high pitch sound, and i turn off the motor. i restart, i noticed the engine is rocking back and forth, very rough idle, it's like the engine starts to die, then it would idle up high, then down, then high, then down and finally dies. i tried to start again with the same result. there is no check engine light and or errors on the intrument panel and noticed a hissing sound. what is wrong? how to fix?
i checked all vacuum lines, all intact. timing? camshaft position sensor? don't think i can drive it... help
dacollector is offline
post #2 of 45 (permalink) Old 07-02-2011, 04:02 PM
Roadking999's Avatar
Date registered: Apr 2008
Vehicle: E350 4M 06
Quoted: 6 Post(s)
Please provide details on your car, model, year, mileage etc...
Roadking999 is offline
post #3 of 45 (permalink) Old 07-02-2011, 05:25 PM Thread Starter
2003 E500, 93000 mileage.
E55 Amg Kit
E55AMG Exhaust
E55 Brakes
E55 Sport Pedals
CLS 63 Cluster
Euro Bumper Strips
Parktronics
Euro Command
Ipod Kit
MP3 Disc Changer
TV Tuner
Navigation
PF Mirrors with Convex Mirror
Lowered Via Links
One Touch Pano Roof Close
Bi Xenon Headlights
Illuminated Door Sills
07 LED Tail lights
07 Trunk Finisher
LED Licence Plate Lights
Euro Emergency Triangle
Wood Leather Steering Wheel
Moulded Driver Door KeyHole
post #4 of 45 (permalink) Old 07-03-2011, 04:00 AM
juancpath's Avatar
Date registered: May 2005
Send a message via AIM to juancpath Send a message via Yahoo to juancpath
an error code would be best.... does the rough idle go away when you go to neutral? Also, does it go away when you drive the car for a half hour or so?
juancpath is offline
post #5 of 45 (permalink) Old 07-03-2011, 10:31 AM Thread Starter
it wont idle long enough for me to drive, or go away in any gear. i am leaninig towards a loose cam gear????
post #6 of 45 (permalink) Old 07-03-2011, 12:00 PM
Date registered: Jul 2005
Quoted: 1010 Post(s)
It does not sound like it. You would hear it in the upper engine if it was that bad. What is the the service history of plugs, fuel filter and other
fuel/ignition items?
Noodles is offline
post #7 of 45 (permalink) Old 07-03-2011, 04:56 PM Thread Starter
hey noodles,
the plugs, fuel filter, and other items hasn't been changed or serviced, but the car starts up fine, just seems like the timing is off causing the engine to rock back n forth, then it dies. could it be electrical?
post #8 of 45 (permalink) Old 07-03-2011, 05:29 PM
Timing is all electronic, if a bad plug, wire, coil pack or fuel system item is past its service life then as hard as the ECU tries it can not smooth out the condition.
All that being said a misfire would throw a CEL and store a code.
It makes me wonder if an engine mount has given up. I had one just act up on the ML. It
was already weak and then one more start and it collapsed yielding a rough idle.
Once on the road the truck was fine.
What does it drive like, if you have driven since this started?
Noodles is offline
post #9 of 45 (permalink) Old 07-03-2011, 06:44 PM Thread Starter
can't drive it, it wont idle long enough to put it in gear, it would be in gear, once i press on the gas, it dies. so if it stores a code, a regular obdII scanner wont pick it up?
post #10 of 45 (permalink) Old 07-03-2011, 11:02 PM
It may depending on the code. It is well worth trying.
There are a lot of possibilities so it is too hard to tell without seeing the car. As far as you
can take the diagnosis will save you $$$$$$. For example if it is a CPS you will save $150
doing it yourself.
Noodles is offline
    Ml320 Rough Start & Dies at Idle rpesnaux W163 M-Class 27 08-03-2010 08:14 AM
    560 hard starting and rough idle - dies when in gear (not always) - need some help... horst-dubai W126 S,SE,SEC,SEL,SD,SDL Class 1 06-17-2010 08:23 AM
    260e rough start/rough idle/shudder CaprezMercedes W124 E,CE,D,TD Class 14 05-25-2010 02:36 PM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-23-2010 12:28 AM
    ignition, start, rough idle, then smooth idle Guest (MBNZ) W201 190-Class 4 08-07-2002 09:57 PM
