Poly V Belt Replacement - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 07-01-2011, 03:49 PM   #1 (permalink)
Date registered: Jul 2006
Vehicle: 2005 E500S4
Guys,
I looked all over the site and searched for a procedure for poly V Belt replacement for 2005 E500 4matic wagon and can't find anything. I saw one for a diesel but not the same. Here are my questions:
1) Should I replace the tensioner assembly at 100,000 miles?
2) How do I remove the tensioner assembly? I have the old style "A" per the service manual.
3) How do I release the tension to replace the belt only? If I do not want to replace tensioner assembly.
The service manual shows a tool that looks like it connects to the center of the tensioner pulley. Do I use that to relieve the tension to remove the belt. I tried relieving the tension by holding it with my hand and pulling and could not budge it. Thanks for your help
Jeff.
Jeff
2005 E500S4 Everything except Distronic and Heated Steering Wheel. "87" Porsche 928S4, "87" Porsche 944
jpuzas is offline   Reply With Quote
Old 07-01-2011, 04:14 PM   #2 (permalink)
Roadking999's Avatar
Date registered: Apr 2008
Vehicle: E350 4M 06
Jeff,
1- Yes, by all means, change the tensioner as well, most belt problems are caused by worn out tensioners, try to get a Gates tensioner from an auto parts store, the one that was in my car was a Gates tensioner with a MB logo and it was identical to the one that I bought from the local auto parts store. You will probably save a lot of money.
2- The old style has a male torx on the pulley, you need a E10 female socket, using a ratchet, rotate counter clockwise and insert a pin or a fat nail to preload the tensioner in the back, if you're not sure how to do this, buy a new tensioner and look in the back to see how it is done. Remove the belt then the 2 bolts holding the tensioner to the engine block.
3- Just follow 2 without removing the tensioner, release the tensioner by rotating it counter clockwise until you're able to remove the pin, then ease it in a clockwise direction.
Roadking999 is offline   Reply With Quote
Old 07-01-2011, 07:29 PM   #3 (permalink)
[QUOTE=kiblawi1;4788975]Jeff,
QUOTE]
If you could look straight at the tensioner pully would the male torx be at 11 oclock or more like in the area of 6 oclock? I see a male torx from up top but it looks like one that secures the tensioner to the block
Thanks
Old 07-02-2011, 04:14 AM   #4 (permalink)
Vehicle: E350 4M 06
If you don't see the torx, then you probably have a new style tensioner with a 17mm nut right next to the pulley, use a 17mm socket and a 1/2 inch ratchet to get leverage and follow the procedure above, if you're not sure; PM me a picture and I'll confirm.
Bookmarks
poly V belt Zill W210 E-Class 20 02-15-2013 08:07 AM
How long does the Poly belt normally last on the G55? aknutsen G-Class 7 04-02-2010 10:40 AM
How much for Poly-V belt change? rinosaur W203 C-Class 4 06-03-2008 04:28 PM
Poly-v belt SilverMPower W163 M-Class 2 12-19-2006 04:50 PM
poly belt / timing belt tsecolin General Mercedes-Benz 0 01-31-2005 10:32 PM
