Oil leak Help! - Mercedes-Benz Forum
post #1 of 31 (permalink) Old 04-09-2011, 06:33 PM Thread Starter
Date registered: Jul 2004
Quoted: 2 Post(s)
Oil leak Help!
My 07 e350 2 wheel drive has started to leak oil. It only has 54k. It is coming from the back of the engine in front of the driver side close to the firewall. It looks like it is coming from below the valve cover gasket but not the oil cover. Any ideas and can it be fixed without taking it to the dealer. I am somewhat mechanical. Thanks
Lotusing is offline
post #2 of 31 (permalink) Old 04-09-2011, 10:49 PM
Date registered: Jul 2005
Quoted: 1117 Post(s)
You are going to have to clean up that area and then leak for its source with it cleaned up.
Too hard to diagnose over the net without pics.
Also a small amount of oil can look like a lot more than it is when it spreads out.
Noodles is offline
post #3 of 31 (permalink) Old 04-10-2011, 05:35 AM
Benzer0matic's Avatar
Date registered: Mar 2010
Vehicle: 08' E350 4matic
My 08' developed a leak in the same location, it was the valve cover gasket and, I think, some sort of expansion plugs. Fixed under warranty
Benzer0matic is offline
post #4 of 31 (permalink) Old 04-10-2011, 10:45 AM
Roadking999's Avatar
Date registered: Apr 2008
Vehicle: E350 4M 06
Quoted: 6 Post(s)
On my 06 E350 4M,I've had the valve cover gasket, expansion plug and camshaft cap (round black 2 inch cover) all leak at different times, they were all repaired/replaced under warranty. If you're out of warranty and you want to DIY then do what Noodles suggested above to find the source, use a mirror to pinpoint the leak.
Roadking999 is offline
post #5 of 31 (permalink) Old 04-10-2011, 11:05 AM Thread Starter
Quoted: 2 Post(s)
Thanks for the reply. It looks like the expansive plug is leaking. Looking at it closer the valve cover is dry. Is it difficult the change the expansive plug?
Lotusing is offline
post #6 of 31 (permalink) Old 04-10-2011, 12:58 PM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 218 Post(s)
Check PM
konigstiger is offline
post #7 of 31 (permalink) Old 04-10-2011, 04:08 PM
Our 05 started to leak last month and I had it fixed under warranty, eleven hours labor for several different things on the engine (valve covers and something else) and 2 leaks on transmission. Free!!!
Dan
2013 E350 Sport
2006 E350 Sport
2005 E320 4matic P2
1983 240D (mint)
1999 Boxster
2011 GMC Sierra
50' Ocean Alexander w/twin 400hp Detroits.
DANSMB is offline
post #8 of 31 (permalink) Old 04-10-2011, 05:40 PM Thread Starter
Quoted: 2 Post(s)
Free, how did that happen?
Lotusing is offline
post #9 of 31 (permalink) Old 04-11-2011, 12:00 AM
He has the CPO extension on the warranty from MB.
Noodles is offline
post #10 of 31 (permalink) Old 04-14-2011, 07:21 PM
Date registered: Nov 2002
Vehicle: '82 500sec euro, '95 Ford F150
Quoted: 102 Post(s)
the e320 wagon I bought recently is leaking like sieve from the upper oil pan AND the rear main seal. As most of you know there is no gasket, only sealant (why?)
BTW the car only has 68K.
It also has the usual bad motor and trans mounts- vibrating like a well used Kia.
All these issues are preplexing to me considering the overall excellent condition of the car, and my previous experience with the w126 cars.
roadhouse is offline
Engine oil leak - front pulley oil leak? southbusiness W210 E-Class 4 04-25-2009 05:41 PM
Head gasket oil leak...stop leak products? lisam W202 C-Class 8 04-11-2009 02:55 PM
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
oil leak... motor honey?...leak stop? b2d W123 E,CE,D,CD,TD,TE Class 1 04-11-2005 03:07 PM
My car is in the shop...Oil leak, windshield washer leak, and screw came off. chanm W163 M-Class 3 05-23-2003 06:21 AM
