Battery symbol on dash board? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-25-2010, 10:37 AM Thread Starter
Date registered: Oct 2008
Hello All,
I have a 2006 E350 with 50K miles, today the battery symbol show up on dash board, the car still start fine. it's time to replace the battery, and can I buy it at local shop?
Hope this just the battery and nothing major.
Thanks for any feedback
tc_sj is offline
post #2 of 11 (permalink) Old 08-25-2010, 05:08 PM
2sic's Avatar
Date registered: Aug 2008
Vehicle: 2009 E-350
Send a message via AIM to 2sic
you can get it at walmart.....just do a search in the forum and youll find the crossover number.....
2003 e320 white w/ blue interior and pano roof.
2sic is offline
post #3 of 11 (permalink) Old 08-25-2010, 10:31 PM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Originally Posted by tc_sj View Post
Hello All,
Is that a facelift or pre-facelift W211? If you follow the above post and buy a new battery, you should know if it is the AUX battery (most likely if the car starts well) or the main battery.
Diesel Benz is offline
post #4 of 11 (permalink) Old 08-26-2010, 11:04 AM Thread Starter
Smile
I dont quite understand facelift or pre-facelift W211?
I checked the voltage on both battery as follow:
car not running
AUX 12.26 & Battery 12.27
car running
AUX 14.28 & Battery 14.28
Now I dont see the symbol show up on dash board any more, this is really strange
Thanks
tc_sj is offline
post #5 of 11 (permalink) Old 08-26-2010, 12:20 PM
Quoted: 40 Post(s)
car not running
car running
Thanks
I understand now that you have a pre-facelift W211. You should check the battery after the car has been parked for some time (over night), before you switch ignition on or at least before you start the engine, preferably at the event you see the battery warning.
Now you have checked that the AUX battery relay seems to be fine. The AUX battery is not completely dead but either one could be bad.
post #6 of 11 (permalink) Old 08-27-2010, 06:11 AM
2sic's Avatar
Vehicle: 2009 E-350
i had the same prob last week, but my aux battery was only showing 10.2 with the car off....i swapped it out and its been fine since....
2sic is offline
post #7 of 11 (permalink) Old 09-01-2010, 07:33 AM
Date registered: Sep 2010
Vehicle: 2006 E350
I'm having the same issue with my 2006 E350. I replaced the main battery yesterday, took it for a short drive (5 miles+) and everything seemed fine. But this morning, the battery warning light was on again. On restart, it went away. I guess it's the aux battery that's bad.
No local shop seems to carry it but I did find:
http://www.amazon.com/UPG-UTX14-Adventure-Sealed-Battery/dp/B001ZTDGAQ
Is this the correct battery? Also, is there anything else I should check? I'm fairly handy with cars but we got this car not too long ago, used, so I haven't done anything aside from the wipers and now the battery.
dsmegst is offline
post #8 of 11 (permalink) Old 09-01-2010, 09:17 PM
Date registered: Jul 2005
Quoted: 1145 Post(s)
Sears, Batteries Plus, Autozone, some Wal-Marts all have AGM sealed batteries that fit these cars
for a lot less money than the dealer. Just make sure you charge the AGM battery for a
few hours at 2 amps before installation for best results.
Noodles is offline
post #9 of 11 (permalink) Old 09-02-2010, 01:07 AM
Date registered: Jul 2009
Vehicle: 2009 Audi S5 4.2L 2006 Mercedes CLS 500
Following motorcycle batteries can potentially be used as AUX battery's replacement:
Walmart Everstart Maxx 14-BS AGM
Autozone/Delco GTX 14-BS
Sears CB12C-A
Interstate CYTX 14-BS (at local firestone)
YB12AL-A2 Xtreme AGM
Yacht CTX12-BS ETX-12/12BS
The key word is 'potential'. Do your own DD before purchasing one and make sure you are getting an AGM (VRLA) battery.
In addition read following post for instructions to get yourself started.
http://www.benzworld.org/forums/3215940-post8.html
Raindrop is offline
post #10 of 11 (permalink) Old 09-02-2010, 07:40 AM
Vehicle: 2006 E350
Thanks a lot for the replies.
dsmegst is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Red battery symbol warning lorenzolmiami R230 SL-Class 15 02-25-2010 04:02 AM
3 Lights on Dash -- Symbol, ESP, and ABS? Maximos W140 S-Class 18 08-17-2009 09:46 AM
Defective light symbol on the dash s2vto V-Class 3 03-17-2009 01:54 PM
Visit Workshop ?? with a battery symbol valmomo69 W251 R-Class 3 01-20-2007 03:38 PM
Dash -- is the gas pump symbol meant to illuminate when low on fuel? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 6 12-13-2005 01:50 PM
