2004 E500 Blutooth USB conversion - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 08-23-2010, 08:30 AM Thread Starter
Date registered: Mar 2010
Is there a conversion package (Benz or aftermarket) out there that will enable me to use a USB flash drive to play MP3 files on the existing sound system. Also to be able to use my Nokia N95 cell phone with the existing phone system and Mercedes voice command. My phone also has ability to store and play MP3. It would be ideal to be able to have independent control over the playing of MP3.
Jon E X is offline
post #2 of 9 (permalink) Old 08-23-2010, 10:33 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
You should indicate your location, preferably at your profile. Phone options are very much market area dependent.
If you have the OEM phone kit, you should be able to plug in a BT adapter allowing you to use your N95 and control it from the car.
You could plug the N95 to your AUX input but I doubt you could find a way to control it for MP3 titles from the car.
Diesel Benz is offline
post #3 of 9 (permalink) Old 08-23-2010, 10:47 AM Thread Starter
Thank you for the reply. I am from Toronto and am not sure what type of aftermarket solutions will work. If anyone has had any successful conversion I can source out any where I have to go to get. How would such a device be installed and who would be the best to attempt. Are there any adaptors that can plug my cell phone into the OEM phone kit that exists in the car. I have a cassette player and tried the cassette adaptor but this is poor quality noisy junk.
Jon E X is offline
post #4 of 9 (permalink) Old 08-23-2010, 01:04 PM
Quoted: 35 Post(s)
I'm not sure if you are talking about MP3 stuff or hands free operation.
For hands free you do not need any after market devices. Just buy the correct MB BT adapter for your car. I think the US products are valid for Canadian cars too:
Home
Sounds like you would have the Audio 50 head unit. I'm not sure if there is any OEM AUX audio option for that, other members can help you with this issue.
post #5 of 9 (permalink) Old 08-23-2010, 02:54 PM
Date registered: May 2009
Vehicle: W211 E270 CDI 2003
If you have audio 20 or command you can use a Dension Gateway 500, connects via the fibre optic, ipod, usb and aux plus BT optional, audio 50 Gateway Lite MOST (ipod and USB but no bluetooth option) + Fiscon Bluetooth (controlled via steering wheel, contacts etc on display in speedo mic would be only non-standard visible part)
Iris-incar is offline
post #6 of 9 (permalink) Old 08-24-2010, 12:52 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
It's not likely you'll be able to connect "music" to your COMAND via Bluetooth.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #7 of 9 (permalink) Old 08-24-2010, 01:10 PM
Date registered: Jul 2005
Quoted: 1016 Post(s)
Also depending on Bitrate Bluetooth won't be able move the data fast enough without
dropouts in the data stream that carries the music.
Noodles is offline
post #8 of 9 (permalink) Old 08-24-2010, 11:52 PM
Quoted: 35 Post(s)
Actually our W204 does it via the UMI/Navigation 20 interface that supports the specific bluetooth streaming profile. New Comand units seem to be coming with this support but it has not been activated (like the W212).
For the W211 music over BT should not be possible with OEM components.
post #9 of 9 (permalink) Old 08-25-2010, 12:38 AM
Gateway 500 will support A2DP music streaming profile with your N95. Fiscon kit will also support A2DP but is only a mono connection AFAIK.
Dension Gateway 500
Bluetooth for Gateway 500
Gateway 500 is a great product, OEM-like in operation
    E500 manual conversion. Ever done or possible? nikch86 W124 E,CE,D,TD Class 22 06-14-2010 03:39 AM
    Has anyone done the spring conversion on a e500?( dsm2925 W211 E-Class 2 12-12-2009 05:37 AM
    Blutooth on the R350 dforman W251 R-Class 7 06-01-2008 10:48 AM
    PLS HELP!!! Deciding to buy either a 2003 E500 or a 2004 E500? nprakash21 W211 E-Class 12 06-19-2007 02:47 PM
    Help... 2004 BMW 545i --OR--- 2004 E500 bigbulus W211 E-Class 3 01-25-2004 10:37 AM
