E350 check engine light and engine noise issue - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-24-2010, 02:39 PM Thread Starter
Date registered: Jun 2010
Let me first let me let all you know that there is a lot of good information on these forums and thanks for the information.
I have an issue with my 2006 E350. I am the original owner and currently have 47,700 miles. I have had an issue with my car for a couple years now. The engine runs smooth but make a noise like diesel engine. I brought the car in under warranty a couple times for the issue, but they could not hear it or identify it. Of course, after my warranty expried, about 3 months later, the engine light came on with these codes (I have access to mercedes certified techs outside of dealer to run codes):
P0016 Crankshaft Position –Camshaft Position Correlation Bank 1 Sensor A
P0017 Crankshaft Position –Camshaft Position Correlation Bank 1 Sensor B
Both of these sensors were replaced and the engine light went off for about a week, and now presents with the same codes. I have been told the codes and the sound have to do with the balance shaft. Is this the case in your experiences? If so, is it really a $5k service task?
Any other ideas out there?
Should I try to make an issue of it with the dealer, since it has already been documented as an issue a couple when I brought it in for the noise. The only reason I hesitate to do that is because I do not want that to have an impact on me if I decide to get an extended warranty to fix the problem.
Thanks for your input guys!
skalacorp is offline
post #2 of 8 (permalink) Old 06-24-2010, 02:43 PM
Date registered: Jul 2005
Quoted: 971 Post(s)
This is well known issue and MB should cover it. Talk to the service manager. If he does
not attempt to get good will from MB then have the dealer give you the contact info
for the regional MB manager in charge of your region.
Noodles is offline
post #3 of 8 (permalink) Old 06-24-2010, 02:59 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Definitely hound the dealer particularly since it existed prior to the warranty expiration.
Check out this thread (particularly the pics!) at benz obsession to understand what's going under the engine covers.
Are you OBSESSED about your Benz? |Attn! Owners '06-'07 MB's with M272 or M273 engines
Check Codes is offline
post #4 of 8 (permalink) Old 06-24-2010, 03:03 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Dealer should refer to Dealer Technical Bulletin (DTB) S-B-03.30/08j for information on balance shaft problems.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 8 (permalink) Old 06-24-2010, 03:14 PM
Date registered: Jul 2009
Yes, it's about a $5K fix. Mine was done under warranty.
hiker64012 is offline
post #6 of 8 (permalink) Old 06-25-2010, 09:18 AM
Date registered: Nov 2007
Service shuttle... R350 at local dealer near me had diesel sounding engine.... too i ask is this the Diesel version and he said no
hawk25 is offline
post #7 of 8 (permalink) Old 06-25-2010, 09:24 AM Thread Starter
Thanks for all the great input everyone. I'll you know the outcome.
post #8 of 8 (permalink) Old 08-24-2010, 11:24 AM
Date registered: May 2010
I was wondering what happened?? Did you get it fixed? I have the same issue.... !!!
Yasso is offline
    06 Mercedes E350 check engine and code issue skalacorp W203 C32 AMG, C55 AMG 0 06-24-2010 02:24 PM
    Check Engine Light 2006 E350 gemee W211 E-Class 4 02-28-2010 04:25 AM
    Check Engine Light 2006 E350 gemee W212 E-Class 5 02-24-2010 12:13 AM
    Check engine light issue Chipsterbenz C208/A208 CLK-Class 4 02-19-2010 04:24 PM
    2003 E350 4MATIC - Check Engine Light 1099gentry W211 E-Class 8 10-27-2009 08:47 PM
