auto window open/close? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 06-05-2010, 01:04 AM   #1 (permalink)
Date registered: Aug 2009
Vehicle: 94 S320 4speed, 2008 W211
I thought I read if you hold the remote door lock/unlock button it will open/close all windows but it didn't work with mine. Is this a feature?
sclass200812 is offline   Reply With Quote
Old 06-05-2010, 03:35 AM   #2 (permalink)
eric242340's Avatar
Vehicle: S320 (W220) and Zotye 1.3/Rolls Royce on back order (LOL)
It was not fitted to all cars, ask your dealer to check the vin on yours to see if it was fitted.
ERIC.
eric242340 is offline   Reply With Quote
Old 06-05-2010, 11:55 AM   #3 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
Also it isn't sufficient to just press and hold the button on the remote because this feature only works via the infrared connection. You have to point the door handle IR receiver with your key.
Also windows (sunroof) have to be normalised (synchronised) before it works, if one touch opening/closing works, then sync is OK.
Diesel Benz is offline   Reply With Quote
Old 06-05-2010, 05:49 PM   #4 (permalink)
Date registered: May 2010
Vehicle: 07 E350, 05 Clk320
On my E350, '07...I must be not farther than 1 meter from the drivers door handle for this to work, and yes all windows and the roof slide open...first lock the doors with the remote, let it settle down and lights are off, then depress unlock and then depress unlock again :and hold it in, if you have this feature you will start grinning at this point....
geezergolf is offline   Reply With Quote
Old 06-05-2010, 07:17 PM   #5 (permalink)
olsb19's Avatar
Vehicle: E320 2004
Talking
I am grinning right now. Thanks.
E320 2004
300E 1990 that I had it for 11 years and it is resting now ( I think ) Amazing car.
olsb19 is offline   Reply With Quote
Old 06-06-2010, 02:28 AM   #6 (permalink)
eric242340's Avatar
We have a winner
Old 06-06-2010, 01:47 PM   #7 (permalink)
w211 door close
1)What do you mean synchronized? 2)What is name of this feature?
Old 06-06-2010, 01:48 PM   #8 (permalink)
Auto window open
I have to hold it down twice? Or once is enough?
Old 06-07-2010, 07:35 AM   #9 (permalink)
Date registered: Sep 2005
Vehicle: 2007 E550 4Matic P2,Pano,Voice,Park,Trunk,Fold Seats, Black/Ash;;; 1989 560SL (sold 11/1/10)
I believe you can press unlock and hold it and it will open everything if you are pointing at the door handle and close enough. Same thing with the lock button once. If you have a pano roof the auto close does not work. The pano roof will only close if you hold that button in all the way. It is not one touch. Also, you can close all windows inside the car by pressing and holding down the air recycle button the climate control system. Again, I doubt this would work with pano but I haven't tried it.
everettpa1 is offline   Reply With Quote
Old 06-07-2010, 10:04 AM   #10 (permalink)
If you look at your manual, you find the feature is called "convenience closing (opening) feature".
Sync means that the door control unit is made aware of the window end positions, up and down. This has to be done if the control unit has lost power for some time (like battery disconnected or a blown fuse). If one touch opening/closing does not work (applies for the sunroof too), then you know that window sync is needed.
Bookmarks
Retrofit window open/door open feature on 2001-? stim141 W208 CLK Class 2 01-27-2010 03:40 PM
Only one window lost its auto close/open feature?? MaximRick W140 S-Class 7 10-11-2009 12:56 PM
Trunk auto open/close not working Crapjokes W215 CL Class 7 07-19-2009 02:03 AM
300ce auto window close conleycrew3 W124 E,CE,D,TD Class 3 11-11-2005 05:02 AM
Windows will not auto open/close..... Fan2zee W140 S-Class 2 04-12-2005 06:06 PM
