Troubleshooting Alarm - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 05-31-2010, 11:18 AM Thread Starter
Date registered: Mar 2009
Vehicle: 06 CDI
Hello...My alarm stopped working for some reason. I know this because the it doesn't chirp when i unlock/lock the car. I checked the fuses in the trunk and the driver side panel of the dash. nothing blew.
So i am stuck in the next steps of figuring out whats going on. I have no information in the dash indicating any doors or hood pins arent working properly.
Any suggestions?
Thanks.
beafer is offline
post #2 of 9 (permalink) Old 05-31-2010, 11:32 AM
Date registered: Jul 2005
Quoted: 1119 Post(s)
What year is your 211?
Noodles is offline
post #3 of 9 (permalink) Old 05-31-2010, 11:36 AM Thread Starter
Vehicle: 06 CDI
sorry i didnt mention that before.
its a 2006 CDI
Thanks.
beafer is offline
post #4 of 9 (permalink) Old 05-31-2010, 11:53 AM
The lack of the chirp does not always mean the alarm is broken. Are you getting
the flashing LED on the dash once you lock the car with the remote?
Noodles is offline
post #5 of 9 (permalink) Old 05-31-2010, 12:05 PM Thread Starter
Vehicle: 06 CDI
the indicators on the dash light up fine as well the outside lights. All the functions of the remote (lock/unlock/trunk) work EXCEPT the panic.
beafer is offline
post #6 of 9 (permalink) Old 05-31-2010, 12:10 PM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 218 Post(s)
Siren unit may need replacement I can send instructions for visual inspection of connections and/or DIY replacement if out of warranty – PM email address.
konigstiger is offline
post #7 of 9 (permalink) Old 05-31-2010, 12:15 PM Thread Starter
Vehicle: 06 CDI
it is out of warranty. Does the alarm atleast blink the lights when its going off, like if i push the panic?
Sending PM now. Thanks.
beafer is offline
post #8 of 9 (permalink) Old 10-26-2010, 08:01 PM
Date registered: Feb 2009
Vehicle: 2007 E350 4MATIC
Just came across this thread and it's the same situation I'm in - the siren/alarm on my 2006 E350 no longer works. When I press the panic button the lights flash but there is no sound. My toddler son had apparently hit/mashed the panic button and it had been going off in our detached garage for quite some time. Now it no longer makes any noise at all.
Any way you could share the visual inspection or DIY replacement instructions?
jochod is offline
post #9 of 9 (permalink) Old 08-09-2011, 09:38 AM
Date registered: Aug 2011
Sounds like it is definitely the alarm siren unit which is faulty. I had the same fault in a 30,000 mile UK R/H drive 2007 220 CDI and the alarm is under the R/H wheel arch. The mechanic replaced it and it was covered in road mess and had destroyed itself. A very common fault in Mercedes E Class, apparently. The high tone horn (the one that is at the front of the car) had similarly perished also, and was replaced too.
Organist is offline
AC troubleshooting brandon671 W126 S,SE,SEC,SEL,SD,SDL Class 2 09-15-2007 12:26 AM
Can the factory alarm be codes so that it beeps when the alarm is engaged and the light flash HACK THT W163 M-Class 0 03-18-2006 07:10 PM
AC Troubleshooting mark2280 W126 S,SE,SEC,SEL,SD,SDL Class 4 06-21-2005 09:24 PM
AC Troubleshooting mark2280 W126 S,SE,SEC,SEL,SD,SDL Class 0 06-16-2005 11:01 AM
Audio clip of the panic alarm - alarm + Hella air horns... Drew W163 M-Class 0 10-10-2003 06:35 PM
