Brake dust cover - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-29-2010, 11:37 PM Thread Starter
2004E320's Avatar
Date registered: May 2010
Vehicle: 2004 E320 Wagon
Brake dust cover
Just wondering what the general consensus is out there regarding the covers you mount between the wheel and rotor. Do they work as advertised? Any negative effects on the brakes? Worth the price? I may choose to do it for the front wheels only.
Thanks,
2004E320 is offline
post #2 of 7 (permalink) Old 05-30-2010, 04:57 AM
Date registered: Mar 2010
Vehicle: 2006 E350
If you search the forum you'll find many threads on this topic. There are a lot of opinions, both pro and con. I have purchsed a set but have yet to install them. I've been having some success using Armor All whell protectant. The rims stay a bit cleaner between cleanings and are much easier to clean. Also, a good coat of wax on the rims seems to help.
Bogey887 is offline
post #3 of 7 (permalink) Old 05-30-2010, 06:06 AM
Date registered: Feb 2010
switching to low dust pads is the best long term solution
fins is offline
post #4 of 7 (permalink) Old 05-30-2010, 01:29 PM
vettdvr's Avatar
Date registered: Mar 2007
Vehicle: E500
My wife keeps the wheels turning and you can't see the dust. 98000 and still climbing.
vettdvr is offline
post #5 of 7 (permalink) Old 05-30-2010, 08:02 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Not an opinion but a fact: Mercedes expressly prohibits use of these things.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #6 of 7 (permalink) Old 05-30-2010, 10:40 PM Thread Starter
2004E320's Avatar
Ok, thanks for your comments. I will try the cleaner + polish and see how it works.
2004E320 is offline
post #7 of 7 (permalink) Old 05-31-2010, 04:55 AM
Vehicle: 2006 E350
Can anyone quote a source on that? here is a snippet from SilverStar Outfitters on the shields:
"Kleen Wheels Dust Shields fit inside rims and prevent brake dust from accumulating on wheels. Vents in the high-strength aluminum alloy discs direct cooling air across brakes. Easy to install. Will not affect Mercedes-Benz new car warranties."
I'd be surprised if they'd post that if it were expressly forbidden
Bogey887 is offline
Need a car cover - indoor, garage, dust cover type thing POS W126 S,SE,SEC,SEL,SD,SDL Class 7 07-11-2012 02:19 PM
Excessive brake dust - Brake issues? Mr_Slugger W204 C-Class 15 04-06-2009 12:23 PM
Brake Dust XXVII - Son of Brake Dust Meets Godzilla ScottinSoCal R/C107 SL/SLC Class 4 07-22-2007 07:57 AM
Dust cover for R107 tanmervin R/C107 SL/SLC Class 8 07-12-2006 04:36 AM
Tired of Brake Dust? Consider getting some Porterfield RS-4 brake pads... SteveL W163 M-Class 5 04-02-2002 12:12 PM
