Air Conditioning Fan or Jet Engine Turbine - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 05-02-2010, 06:50 PM   #1 (permalink)
Date registered: Mar 2010
Vehicle: 2006 E350
Yesterday was pretty warm up this way. The wife and I were heading to an event requiring being somewhat "dressed". I decided to start the car and give the air conditioning some time to pre-cool the car. A couple of minutes later I could hear the fan (inside the engine compartment) running very fast and it was a bit loud. Is this normal? It was really cranking! It slowed down a bit while still idling and the interior cooled down nicely but it did leave an impression, so I thought I might ask the experienced owners if this was typical operation for the AC when the car is idling. The car is an '06 E350.
Thanks,
Mark
Bogey887 is offline   Reply With Quote
Old 05-02-2010, 10:07 PM   #2 (permalink)
Heatwave's Avatar
Date registered: Apr 2009
Vehicle: 2007 E350 Sport
An idling engine has to produce its own airflow to control engine heat ... there's no airflow that occurs when the car is moving. The electric fans cycle on and off, and speed up and slow down, as necessary to aid the radiator in reducing the temperature of the cooling fluid circulating around the engine and through the radiator. At highway speeds, the fans may not cycle on at all, or perhaps only occasionally (depending on driving conditions) because the airflow is assisting the radiator in its function. Based on what you described, it appears your cooling system probably is working properly.
Heatwave is offline   Reply With Quote
Old 05-03-2010, 12:31 AM   #3 (permalink)
Bimbis's Avatar
Date registered: Dec 2006
Vehicle: Formerly a 1990 200E; then a 2003 E320; and now a 2010 E350 P1, P2, Wheel pkg & folding rear seats
i just loove hearing that sound. like a jet engine! and the way it spools up to max voume/speed and spools down when it's cutting out.
and yes, i do believe the system is working just fine.
Bimbis is offline   Reply With Quote
Old 05-03-2010, 02:50 AM   #4 (permalink)
PPBSKIS's Avatar
Date registered: Nov 2007
Vehicle: 05 E500 4 Matic
I know what you mean and I am half deaf. When my car was being picked up for routine service I asked the driver if this was normal and he said that it was common, I also asked the service writer if this was normal and he indicated that nothing was out of the ordinary. It is a heck of a racket though.
PPBSKIS is offline   Reply With Quote
Old 05-03-2010, 04:06 AM   #5 (permalink)
eric242340's Avatar
Vehicle: S320 (W220) and Zotye 1.3/Rolls Royce on back order (LOL)
It is normal, buy an S Class 600 and drive it in the sub tropics and boy you will know what a real jet engine sounds like, they cook so easy
ERIC.
eric242340 is offline   Reply With Quote
Old 05-03-2010, 04:48 AM   #6 (permalink)
Vehicle: 2006 E350
Guys,
Thanks for the response. I thought that was how it was supposed to work but boy that puppy cranks!!!
Thanks,
Mark
Old 08-04-2010, 11:02 AM   #7 (permalink)
Date registered: Jan 2010
Post
i have 03' e320 - w211 the fan (in the engine compartment) is constantly running at high speed, also it started yesterday after we got home from our trip. during our trip on the way home the ac was not functioning properly, the interior ac fan speed worked great, but the air was blowing cool, not ice cold as normal. when i got home i checked under the hood and noticed the ac lines were covered in ice. left the hood open so the ice would melted faster. it took a few minutes for the ice to melt ( live in florida ) and the ac began to blow cold air again but now the fan in the engine compartment is running at a high speed, constantly and will not slow down or stop. this has never happened before.
i can go out and start the car and within about 30 seconds, the engine fan kicks in on high and constantly runs. any ideas? thanks in advance for your response.
domingo56 is offline   Reply With Quote
Old 08-04-2010, 06:06 PM   #8 (permalink)
PPBSKIS's Avatar
My experience with ice on the line sets would be low refrigerant levels, at least in a home A/C system.
Bookmarks
Air conditioning not blowing cold air cooling fan not working vrod1495 R170 SLK Class 0 11-02-2009 04:37 PM
Fan sounds like jet engine '04 CLK 500 pcohen15 W209 CLK Class 9 09-11-2007 11:19 AM
Air conditioning blower fan motor noise jruano R129 SL Class 1 06-02-2005 05:14 PM
air conditioning fan not working! Selma W201 190 Class 3 04-23-2005 04:48 PM
190E Air Conditioning & Cooling Fan Operation scripley W201 190 Class 0 03-02-2004 10:08 PM
