Service Reset on 2006 E350 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-21-2010, 12:18 PM Thread Starter
Date registered: Mar 2010
All,
I'm trying to figure out why I cannot get to the service menu on my 2006 E350 4-Matic. I know this topic has been discussed at great length and I have dutifully searched the forums and tried all the suggested methods to no avail. The most commonly suggested routine is the following:
1 key on #1 position
2 go to mph display in the cluster
3 press trip odometer knob three times (QUICK) voltage will appear on display
4 Select service menu using + or -
5 Service Indicator Displays Items
6 Press the menu systems button until the MPH display appears
This does not work for me at all. I have a feeling that the firmware on my system may have been flashed at the dealer at some point to disable this function.
Any thoughts appreciated.
-Dazed and Confused
ICantDrive55 is offline
post #2 of 8 (permalink) Old 04-21-2010, 01:31 PM
tonyjroy's Avatar
Date registered: Apr 2010
Vehicle: 2005 E320(RIP) 2004 SL500
Quoted: 9 Post(s)
I have a 2005 E320 and this worked like a champ. I don't know if it will work for 2006 but worth a try. The procedure is a little different than what you listed so here it is....
How to reset the Maintenance Service interval:
Set key to position 2
-Scroll to the customer display with the picture of a wrench and what service is due
-Press and hold the reset button for 5 seconds
-Service menu should come up
-scroll up and down using the + and - buttons on the steering wheel
-scroll to confirmation for service. (you have to confirm all items you cannot confirm some and not others)
-Confirm service and you should be all set.
I have heard some rumor that this feature was locked out in 2006 but others have had success. Give it a try.
The first time I tried it I kept getting bumped out of the system. I found this pdf with pictures and it worked like a champ.
Good Luck
tonyjroy is offline
post #3 of 8 (permalink) Old 04-24-2010, 02:46 PM
Date registered: Jan 2010
Vehicle: 2006 E350 4Matic
I followed the instructions in the PDF file that I found and worked for my 2006 E350. I tried the same instruction today to reset the counter but didn't work. I guess it only works if the service notice comes on. In my case, I changed oil way before the notice but couldn't reset the counter.
baboli is offline
post #4 of 8 (permalink) Old 04-25-2010, 04:46 AM Thread Starter
OK. I'm a doofus. Checked again this morning and it works using the 3 quick push method. Now I just need to figure out what a "59M00000031" service is. Thanks.
post #5 of 8 (permalink) Old 04-25-2010, 05:08 AM Thread Starter
OK. Just went through the menu again. When I start the car, I see "Service F exceeded by 214 Days". I believe that Service F is simply a indication of the amount of time needed for the service, in this case 5-6 hours of labor. When I enter the Service Menu to see what service needs to be performed, I see a cryptic 59M0000031 item is +214 days. What the heck is 59M00000031 ? I assume I need the service manual to figure that one out ?
post #6 of 8 (permalink) Old 05-19-2010, 11:08 PM
Rashid Ahmad's Avatar
Date registered: May 2009
Vehicle: E280 - 2007 (W211)
It also works for me. But instead of going from Service F to Service G, it went back to service B.!!!???
Any help here ...?
Rashid Ahmad is offline
post #7 of 8 (permalink) Old 05-20-2010, 08:49 AM
Date registered: Nov 2007
Vehicle: 2004 E500
You don't need to know what a 59M00000031 is. Evidently you've gotten into the "SERVICE DATA." The place you want to be is in "ITEMS," below that. Take a look at Pages 17-20 of this PDF, and I think things will be a little clearer:
http://www.mercedestechstore.com/pdf...2008-16-02.pdf
dang2 is offline
post #8 of 8 (permalink) Old 04-29-2013, 12:30 PM
Date registered: May 2012
FYI - I have a 2007 E350 (W211) and the Reset Instruction in your orig. thread worked.
Just make sure all doors are closed and the key is in Position 1 (that's the position where the Radio and Fan turns on but before all the engine lights come on the dash).
BenzoE350 is offline
2006 E350 Engine Air Filter Location and Service D Reset theszokes W211 E-Class 3 09-15-2010 09:57 AM
Service Timer Reset for 2006 C230 pazo06C230 W203 C-Class 18 09-12-2010 07:42 PM
Reset B Service on 2006 SL500 FBlack R230 SL-Class 0 03-22-2010 10:43 AM
2007 E350 ....x days passed service overdue..oil change...reset indicator? mbgirl123 W211 E-Class 1 03-11-2010 01:18 PM
How to reset 06' E350 service due light? mazeg1 W211 E-Class 2 11-15-2007 09:14 PM
