"rattling" sound on acceleration- 2003 E500 - Mercedes-Benz Forum
post #1 of 35 (permalink) Old 04-10-2010, 09:48 PM Thread Starter
foreyes's Avatar
Date registered: Apr 2003
Vehicle: 03 E500
My 2003 E500 has a subtle noise on acceleration that I would describe as a subtle "diesel-like" clatter, or "tapping noise". It's most pronounced on mild acceleration, and goes away on full throttle. I just bought this car this week and was wondering if this was a normal sound for this V8; although I've had other M-Bs with V8s, none of them have made this sound (32v 91 SL500 & 97 E420) Even after running 93 octane, the tapping noise has not diminished. Is this the sound of a normal 24-valve V8? The car runs very smoothly, with no vibration or hesitation, and feels very powerful too. Crude stopwatched 0-60 times are in the 5.7 second range, so performance is excellent. Any thoughts?
foreyes is offline
post #2 of 35 (permalink) Old 04-10-2010, 10:29 PM
Heatwave's Avatar
Date registered: Apr 2009
Vehicle: 2007 E350 Sport, 2007 SL550
Quoted: 35 Post(s)
"Sounds like" classic pre-ignition, or engine knock. It shouldn't happen, particularly since you're using 93 octane. You might try a different brand of gasoline next time ... maybe a "brand" name, such as Shell or BP. Let us know how this works out. Good luck.
Heatwave is offline
post #3 of 35 (permalink) Old 04-10-2010, 10:46 PM
Date registered: Aug 2005
Vehicle: 2008 C300, 1970 280se convertible,2010 e350
I have been experiencing the exact noise on my 03 E500. I had the car at mercedes dealership a few days ago for another problem and asked them about the noise. they drove the car with me and said the noise is related to engine mounts. Hard for me to accept. i thout it might be cat. converter. The car has 3 of them 2 in front. the part is about $400 and labor about $350. I have not fix it yet, but I will. My car has about 70,000. on it. Good luck.
meran is offline
post #4 of 35 (permalink) Old 04-15-2010, 01:24 PM
CRAZYKEN's Avatar
Date registered: Apr 2010
Vehicle: 2007 E550 4matic w211, 2005 Legacy GT tuned by DPS ATR GT30R70 25psi
Send a message via AIM to CRAZYKEN Send a message via Yahoo to CRAZYKEN
rattle noise...
...check under the car next time its on the lift!
It could also be exhaust noise...snapped hanger or loose heat shield!
my .02 cents,
CK
CRAZYKEN is offline
post #5 of 35 (permalink) Old 04-15-2010, 10:57 PM
Date registered: Feb 2008
Vehicle: 2003 E500 sport
well my car has a rattle when i close the drivers door and it also makes the same noise if the car is started and in park and i give it some gas it will make that noise so get it on a lift of get under it safely and tighten up the bo;ts.
i think there all 8mm.
2003 E500 sport:keyless go:black on black: airmatic:
shaunls1 is offline
post #6 of 35 (permalink) Old 04-19-2010, 07:37 PM
Tap-tap noise did not go away
I spent about $800 hoping to get rid of the tap tap noise but did not work. My car has about 70,000 miles and the old motor mount looked great, no damage at all. But replaced them anyway. The clatter noise, diesel noise or the tap tap continues. Any ideas? The noise is not a losse part. I have switched gas graded and brands, changed motor oil with no luck.
meran is offline
post #7 of 35 (permalink) Old 04-25-2010, 07:51 PM
Were you able to find a reasonable solution to the problem? I know our cars have the same problem.
meran is offline
post #8 of 35 (permalink) Old 04-26-2010, 06:03 AM
vettdvr's Avatar
Date registered: Mar 2007
Vehicle: E500
If I remember correctly the motor mount is a gas charged mount. Mine failed and they "looked great" when removed. They had failed.
vettdvr is offline
post #9 of 35 (permalink) Old 04-26-2010, 06:09 AM
eric242340's Avatar
Quoted: 312 Post(s)
Does it make this noise with the transmission in park and revving the engine or only when in drive and accelerating?
ERIC.
eric242340 is online now
post #10 of 35 (permalink) Old 04-26-2010, 06:11 AM
Zaxler's Avatar
Date registered: May 2009
Vehicle: 2001 E240
If noise is from the underneath of car, best bet is that the cat is gone.
Zaxler is offline
Figured out "banging" or "thudding" sound from rear foolio2 W126 S,SE,SEC,SEL,SD,SDL Class 1 11-24-2009 07:41 PM
"RINGING/RATTLING SOUND" near the lamp switch? MB-IDOL W210 E-Class 0 10-15-2007 04:58 PM
"The Rattler" or "Fixing the rattling steering column." Digmenow R/C107 SL/SLC Class 11 09-25-2007 06:35 PM
Does your 2003 make a "rattling" noise? sakai73 W211 E-Class 3 11-07-2003 10:01 AM
