2002 e320 a/c not working - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-05-2010, 03:38 PM Thread Starter
Date registered: Oct 2006
Vehicle: 2002 MB 320e 97,000
I tried my ac the other day and it's not working. I have the numbers and codes,
1=100 2=75 3=91 4=94 5=82 6=191 7=00 8=78
codes Eb1234, Eb1417
I took a quick look at the compressor and it does not seem to be turning, (the front most hub remains stationary.
After reading about other similar problems I have the following questions?
Is the compressor not turning because the #7 code is 00 which seems to indicate that I have no refrigerant?
I added R134a last year at this time and I had good A/C but the #7 code had a value of 06 when I first checked it before adding R134a.
Should I try to find a leak by adding some type of refrigerant that will allow me to see where the leak is?
Or should I just add r134a and hope the pressure goes up and then it will turn the compressor on, or does something have to be done to let the system know that there is now refrigerant in the system?
Any help or idea are appreciated.
mdsjsb is offline
    will rims from a 2002 CL500 fit a 2002 E320 mhrycyna W210 E50 AMG, E55 AMG 3 01-20-2010 07:40 AM
    will rims from a 2002 CL500 fit a 2002 E320 mhrycyna C215 CL-Class 0 01-11-2010 02:21 PM
    2002 E320 Wagon reverse park passenger mirror stop working MAVA W210 E-Class 3 09-19-2009 02:39 PM
    car purchase: 2003 E320 or 2002 E320 (W210)? ProV1x W211 E-Class 3 03-21-2007 01:04 PM
    2002 e320 wheels/tires NEW DESIGN FOR 2002 Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 01-25-2002 07:10 PM
