How to change Headlights... - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-09-2010, 10:23 AM Thread Starter
Date registered: Jan 2010
Okay,
I just had 3 quotes to install headlight... one place stated $55.00 another place stated they would do it for $85.00 per light. They also stated that they have found that the control unit in these have an issue so it could be the control unit and not just the headlight cause these bulbs typically last 10 years.
Mine is the 2003 Mercedes E500 sport. considering I always allow it to turn off via auto light setting and I have left the lights on over night or over weekend like 15 times... that is about right. Can someone direct me to instructions on doing the lights myself.
thanks
mrowlandE500 is offline
post #2 of 9 (permalink) Old 03-09-2010, 10:34 AM
Date registered: Jan 2007
Vehicle: E350
Quoted: 5 Post(s)
do you have xenon headlights or healogen?
dewana421 is offline
post #3 of 9 (permalink) Old 03-09-2010, 11:37 AM Thread Starter
Low Profile Lights
Xenon... d2s
post #4 of 9 (permalink) Old 03-09-2010, 12:20 PM
Vehicle: E350
Quoted: 5 Post(s)
hope this helps
You will have to remove the entire front bumper to change the headlights.
Try these two links. that should help you.
http://www.benzworld.org/forums/w211...nt-bumper.html
Bi Xenon retrofit 50 pics "56K no!" - MBWorld.org Forums
post #5 of 9 (permalink) Old 03-09-2010, 12:25 PM Thread Starter
d2s headlights
That is a bit much... you sure... Maybe I said it wrong. I just need to replace the bulbs in the headlight housing. I was told that I merely needed to pull them from the back of the housing and turning the bulb. I don't need to take the headlights out.
post #6 of 9 (permalink) Old 03-09-2010, 01:51 PM
1997E300D's Avatar
Vehicle: 2008 ML320CDI Iridium Silver/Black, NAV, P2 pkg, Sirius, Harmon Kardon. Active Bi-Xenon
Quoted: 9 Post(s)
The voltage required to ignite a Xenon light is enough to kill you many times over. If you are going to venture into this task, I would get an account at alldatadiy.com Its pretty darn cheap for one year subscription. I am sure there are instructions on how to change the bulbs.
2008 ML320 CDI. Iridium Silver/Black MBTex, P2 pkg, NAV, Trailer Hitch. Purchased 3/2012 CPO 142,000 miles
2006 E320 CDI Black/Black, Leather, NAV, Harmon Kardon, HTD Seats, Rear Shade. Purchased 2/2010 CPO SOLD
1997 E300D Silver 304,000 miles SOLD
2000 VW Passat 1.8t Black/Black 400,200 miles original owner still going strong 3/2015
1997E300D is offline
post #7 of 9 (permalink) Old 03-09-2010, 04:40 PM
Vehicle: E350
Quoted: 5 Post(s)
ya becuase your heading says how to change headlights..lol..ya if its just a buld then you dont need to do all that...its pretty simple..i donot have the exact instructions but the prices they charging you is crazy..it shouldnt be that much to change a light bulb.
post #8 of 9 (permalink) Old 03-09-2010, 05:17 PM
Date registered: Jul 2009
Vehicle: 2003 e500 W211
I have a 2003 e500 and recently had the bulb replaced...$20 including labor....which took about 5 minutes. I saw him just grab the bulb with his hand without taking anything apart ( passenger side front ). I think on the driver side front u would need to move the coolant or whatever box that is to reach the bulb.
NiwPix is offline
post #9 of 9 (permalink) Old 03-11-2010, 02:05 AM
Date registered: Jul 2005
Quoted: 975 Post(s)
AR82.10-P-1201T Remove/Install Bulbs of Headlamp Unit
- Low beam bulb
- with CODE (614) Bi-Xenon headlamp
- with CODE (615a) Bi-Xenon headlamp unit with integrated cornering lamps
DANGER:
* Danger from Xenon headlamp high voltage
* Do not touch parts which conduct high voltages. Persons with active electronic implants (e.g.heart pacemakers) should never work on xenon headlamps.
1 Disconnect ground cable of battery
2 Remove cover (5) on xenon headlamp
3 Rotate and remove Xenon headlamp ignition module (E1n2, E2n2) on Xenon headlamp
NOTE: Do not break off latching lugs. Electrical connector (4) is automatically unplugged.
4 Turn and remove retaining collar (2)
5 Remove gas discharge lamp (1)
NOTE: Do not touch the gas discharge lamp (1) with your bare fingers but use a grease-free, soft cloth
6 Check power supply contact points for corrosion
NOTE: If necessary, replace corroded part.
7 Insert gas discharge lamp(1) into Xenon headlamp and hold in place
* Ensure that they are installed in the correct position (notch).
8 Put on retaining collar (2) and rotate
NOTE: Note inscription "Top" on the retaining collar (2).
9 Mount Xenon headlamp ignition module (E1n2, E2n2) and rotate
NOTE: Installation position must be noted.
10 Connect electrical connector (4)
11 Fit cover (5) to Xenon headlamp
NOTE: Check seal in cover (5) for signs of damage and wear, if necessary fit a new seal to the cover (5).
12 Reconnect ground lead to battery
13 Carry out function check
Noodles is offline
    How to change b200's headlights? Jamntoast W245 B-Class 56 07-14-2016 09:14 AM
    change r170 headlights boriznl R170 SLK-Class 3 11-22-2008 07:33 AM
    want to change headlights whoachubby W210 E-Class 1 12-05-2007 08:00 PM
    Change headlights? Lars K C215 CL-Class 0 07-22-2004 03:18 PM
