HELP PLEASE!! W211 2003 e320 fault code P2001 with snap on reader - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-16-2010, 05:22 PM Thread Starter
Date registered: Feb 2010
What does this mean P2001 you can disregard or erase this code. Read with a snap on reader INDY can't figure it out really need help tried searching internet found P 2001 NOx Trap Efficiency Below Threshold (Bank 2) PLEASE HELP WHAT DOES THIS MEAN???
clg8888 is offline
post #2 of 10 (permalink) Old 02-17-2010, 05:31 AM
Date registered: Jun 2005
Vehicle: 2003 E320 - wife's car now; 07 Porsche Boxster S - my car!!
Sent you a PM.
Regards,
paul....
paulv is offline
post #3 of 10 (permalink) Old 02-17-2010, 09:32 PM Thread Starter
went to the indy again and had the CEL cleared drove 50 miles today crossing my fingers no CEL light for today
clg8888 is offline
post #4 of 10 (permalink) Old 02-18-2010, 09:21 AM
The P2001 is for the EGR system which is tested once per drive cycle. If there's still a problem, you'll get the CEL after the second drive cycle (first drive cycle will store a pending code). Good luck.
Regards,
paul..
paulv is offline
post #5 of 10 (permalink) Old 02-18-2010, 05:40 PM Thread Starter
Thanks Paul you are correct 2nd drive cycle and CEL is back on again. How do I go fixing this what part do I need to check/clean or replace 2 answers I found on the mb forums P2001 Component N15/3 (ETC control module) is faulty.
P2001 Malfunction of exhaust gas recirculation (functional chain)(P0400). I do not have a P0400 code coming out is it the ETC module is this part of the SBC module? just had it replace at 99k now i am at 103k way pass extended warranty need your help again thanks!! p.s. my e320 is the V6 gas base 2003
clg8888 is offline
post #6 of 10 (permalink) Old 02-18-2010, 10:58 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Transmission is not controlled by the SBC control unit. I do not remember these codes by heart but if paulv says one thing, why do you seem to ignore that and refer to some other info somewhere else? I would be very surprised if his advice had mistakes, even accidentally.
Diesel Benz is offline
post #7 of 10 (permalink) Old 02-18-2010, 11:02 PM Thread Starter
just paranoid!!! hahaha will have indy check EGR tom.
clg8888 is offline
post #8 of 10 (permalink) Old 05-12-2014, 08:36 AM
Vehicle: 1998 SLK 230, 2016 Tesla Model S P90D, 1984 Alfa Spider Veloce, 2008 E320 Bluetec (former)
I also have it.
So, I've been having the P2001 NOx trap below efficiency code being thrown on my 2008 Bluetec, along with a P0101 (MAF circuit out of function range). I took out the EGR, cleaned the hell out of it, put it back. Also cleaned the MAF (which was replaced last year, and initially had a P0101, but the indy didn't realize he had to re-map the airflows...). I didn't seem to have the P0101 before the P2001 popped up, so I think it could be related. Performance-wise, it seems ok off the line (if not slightly sluggish), downshifts definitely sluggish), overall slower than it's normal tuned self (German tuner box). So, that all being said, what would be the next step? Attempt to replace the EGR valve altogether, or go down a different road. I'm almost to the "drop it off at the indy stage".
DO_Doc is offline
post #9 of 10 (permalink) Old 03-04-2015, 08:08 PM
BonitaBeast's Avatar
Date registered: Jun 2009
Vehicle: 2008 G55k, 2006 E55 W211
Hi. Has this issue since been resolved after the work you mentioned?
I am encountering the same issue.
The Stable:
2003 MB G55....k **Kleemannized!! **
2008 Cayenne Turbo (957) **Updated Cooling Pipes**
1988 E28 M5 (DC93 #009) **Full Euro Bumper/Light conversion)**
2015 Indy Fab Ti Deluxe MTB 29er
2012 Indy Fab Ti FLW
2007 Indy Fab Steel Deluxe SS 29er
BonitaBeast is offline
post #10 of 10 (permalink) Old 06-09-2016, 08:36 AM
Yes
It did resolve the P2001 code. Also I found when I replaced it that one of the hoses in the back was kinked up.
DO_Doc is offline
    2003 Mercedes E320 W211 Parting out europart.inc For Sale/Wanted/Trade/Giveaway 30 07-31-2012 11:15 PM
    2003 e320 w211 check engine on snap on tool said disregard or erase codes clg8888 W211 E55 AMG, E63 AMG 0 02-15-2010 06:57 PM
    Help!!!!! C220 CDI and Fault Code Reader mikimogo W202 C-Class 5 06-30-2009 07:01 PM
    '04 E320 Sport Edition (W211 chasis) Fault Code-P0715 DESPERATE!!! PLEASE HELP US!!! poptoy W211 E-Class 7 06-23-2008 12:19 PM
    #11 Fault Code on E320 nightwagon W124 E,CE,D,TD Class 0 11-17-2005 11:18 AM
