Low Battery Warning - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-23-2009, 05:46 AM Thread Starter
Date registered: Nov 2009
Low Battery Warning
My '06 E350 kept giving me the low battery, convention features not available warning every day. Once I drove the car for a few miles, that would go away. I went and got the battery, charger and alternator checked but they were all showing as ok. But now the car won't start at all. Is there way to find out if the battery is bad or if something keeps draining the battery?
yogirane is offline
post #2 of 11 (permalink) Old 11-23-2009, 06:18 AM
Date registered: Sep 2008
Vehicle: 2006 Merc E320 cdi
Quoted: 49 Post(s)
Did you check BOTH batteries? There are 2 batteries in the car. One in the trunk and one in the engine compartment passengers side underneath the cabin filter. You may try searching to see how to replace the auxiliary battery. There have been several conversations on this topic in the past with vendors you may use to pick up another battery.
I've never heard of the auxiliary battery not allowing the car to start, tho...
Good luck.
aeubank is online now
post #3 of 11 (permalink) Old 11-23-2009, 04:37 PM Thread Starter
Ok, I checked both batteries with the volt meter. Still says over 12V. Am I supposed to measure it unhooked from the car?
The dash says Braking Power Reduced. Start Car, but it won't start. I can feel the brake pedal push back when I depress it and hit the start button on the shifter knob.
yogirane is offline
post #4 of 11 (permalink) Old 11-23-2009, 05:06 PM
Vehicle: 2002 mercedes c230 kompressor, 1999 slk 230 kompressor, 1987 buick grand national 3.8 turbo
how long does the vehicle sit? the front battery is for your sensatronic brakes, it only powers the brake hydraulic unit in case of main battery failure. so that u still have full braking power.you may need to take it to a dealership so that they can hook up a computer on it to see if ur network is staying awake(aka CAN system)
benztek80 is offline
post #5 of 11 (permalink) Old 11-23-2009, 05:13 PM Thread Starter
It just started this problem with the low battery warning about two weeks ago. Even if it would sit for 1 day, the warning would come on and you can hear the slowness in the cranking. But after a few miles of driving, the warning goes away. This passed weekend I left teh car sitting for two days and by that time, there was not enough juice to start it.
yogirane is offline
post #6 of 11 (permalink) Old 11-23-2009, 10:09 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
It could be a quiescent current issue but if the car does not start when the (main) battery voltage is at above 12 volts, there must be something else wrong (too).
Diesel Benz is offline
post #7 of 11 (permalink) Old 11-24-2009, 05:43 AM
Date registered: Jan 2009
Vehicle: 95SS(165k) 06CDI(SOLD) 2014 GLK250
Did you test them after a drive?? If you did wait, test them after a day or so...
Just to make sure check batteries when cold with voltmeter to try and replicate the conditions
BlackOpalCDI is offline
post #8 of 11 (permalink) Old 11-24-2009, 05:47 AM
vettdvr's Avatar
Date registered: Mar 2007
Vehicle: E500
NOTE: you can have 12 V and the car still have a bad battery.
You must check the voltage when cranking. IF the voltage drops below 10 V your battery is loosing reserve capacity. Everything described indicates battery failure. I replaced my battery with one from Carquest. They have a European direct fit replacement battery.
vettdvr is offline
post #9 of 11 (permalink) Old 11-24-2009, 06:15 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Originally Posted by Diesel Benz View Post
It could be a quiescent current...
There is a word you don't see every day.
flyboyike is offline
post #10 of 11 (permalink) Old 11-25-2009, 06:49 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
lol thats the fancy word they like us to use for parasitic draw. But i agree that it sounds like you have a bad battery, checking voltage does not do much it should be load tested. And the auxiliary battery powers much more than just the sbc unit in the car when the vehicle is off.
kyle21nluvnit is offline
    Low Coolant Warning BostonC4S W210 E-Class 4 11-07-2007 12:37 PM
    LOW OIL WARNING benzzn55 W210 E-Class 15 09-07-2007 08:52 PM
    Battery warning Prasse W211 E-Class 18 06-22-2006 11:48 PM
    Low fuel warning fgwinn R171 SLK-Class 0 09-14-2004 08:54 PM
    Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK-Class 3 03-21-2001 03:28 PM
