Ball Joints or Bushings - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-09-2009, 12:11 PM Thread Starter
Date registered: May 2008
Vehicle: 2004 E320
Hey Guys,
I'm having a slight squeak from my front driver side wheel. I've done some searching and reading about the ball joints and bushings. My question is this: How do you know if you need to replace a ball joint vs a bushing.
Since I'm going to be in there working, should I just replace all the joints and bushings??
jack@oenophilia.com is offline
post #2 of 4 (permalink) Old 11-09-2009, 07:27 PM
Date registered: Jul 2005
Quoted: 972 Post(s)
I am leaning towards the ball joint. The squeaking when turning the wheels back and
forth has been a symptom of ball joints in my experience going back to my shop days
in the early 90s.
Noodles is offline
post #3 of 4 (permalink) Old 11-10-2009, 02:32 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Post
Originally Posted by jack@oenophilia.com View Post
Hey Guys,
Since you inquire, I'd check the bushings with a pin or drill-bit of the same diameter as the ball joint spindle. There you would see whether it fits well or it has play. And what's not broke, don't fix it unless after a long usage factor or seeing material degrading.
JoeVal is offline
post #4 of 4 (permalink) Old 11-11-2009, 10:08 PM
Mandinga!'s Avatar
Date registered: Oct 2007
Vehicle: E500
squeaks
I spent a whole lotta money on this issue and replaced everything on the driver side to find out it was squeaking on the passenger side, well, I didnt let my mecanic do any work on the pass. side I made him apply lube it came in a syringe. $2600 vs $15 bucks I was livid. squeak is gone
Mandinga! is offline
    At Dealer - Ball Joints and Camber Bushings nmilsaps C208/A208 CLK-Class 2 05-27-2009 03:00 PM
    Ball joints laksa W210 E-Class 9 10-02-2008 01:34 AM
    Question on arm bushings/ball joints debbibaron W210 E-Class 14 11-22-2007 08:23 AM
    sale...ball joints and control arm bushings solarant W124 E,CE,D,TD Class 0 11-21-2007 02:08 PM
    does anybody here grease up the ball joints, cv joints etc ? tirona W210 E-Class 3 03-14-2007 10:57 AM
