» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 11-08-2009, 08:57 PM   #1 (permalink)
BenzE500's Avatar
Vehicle: ABCLOSING
4th trip to Stealership
After my third visit to the dealership they finally fixed my squeaky breaks on my 2009 E350 by replacing the front brakes with new ones. 2 months later they are squeaking again. What should I do?
BenzE500 is offline   Reply With Quote
Old 11-09-2009, 01:47 AM   #2 (permalink)
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Thumbs up Burnishing or Bedding in new brakes to eliminate squeeling noise !!!
I had the same problem with a squeal after doing a brake job and got rid of the squealing noise by following the attached document, courtesy of Marcus and others! One time should be enough, but sometimes it takes two... or three in the worst cases.
There is a brake pad paste that must be applied to the back of the new brake pads... I am assuming that the Dealer followed the correct procedure!
By the way, if the rotors were not changed, the brakes need to be applied hard for the first 100 miles... otherwise, pussy footing the brake will make them squeal like a mouse being chased by a cat!
Good luck...
unitfreebie is offline   Reply With Quote
Old 11-09-2009, 03:31 AM   #3 (permalink)
drivbiwire's Avatar
Date registered: Mar 2006
Vehicle: 2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
Squeaking breaks! Holy cow How many breaks did they find?
Try washing the car and the wheels, BRAKES will squeak when you allow excess dust to accumulate which results in a high resonance chatter from lifting of the pads contact with the rotor aka Squeaking...
drivbiwire is offline   Reply With Quote
Old 11-10-2009, 12:22 AM   #4 (permalink)
BenzE500's Avatar
Vehicle: ABCLOSING
Im taking it in on Friday ill let you know what they say
Old 12-05-2009, 02:32 PM   #5 (permalink)
abiazis's Avatar
Date registered: Jul 2009
Vehicle: 2005 SL 65 AMG
feedback
what did they say?
abiazis is offline   Reply With Quote
Old 12-05-2009, 09:02 PM   #6 (permalink)
Yes, it is always useful to know what the Dealer says to justify whatever they will do or don't do when you complain to them!
I think I know what they are going to say, but I am always open to something new...
Stealership Carolina28 W126 S,SE,SEC,SEL,SD,SDL Class 4 05-22-2006 07:04 AM
British Columbia: Recce trip for the 4th annual G-amboree Chris Ball G-Class 0 05-08-2006 05:02 PM
West coasters - Death Valley Trip April 2nd -> 4th AlanMcR G-Class 31 04-07-2005 08:28 PM
Stealership SIML320 G-Class 2 05-17-2004 01:29 PM
Stealership SIML320 W163 M-Class 4 05-17-2004 12:56 PM
