» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 11-07-2009, 09:17 AM   #1 (permalink)
Date registered: Dec 2004
Vehicle: 2003 E320
WOT, Check Engine Light, error codes?
Hey all,
When I hit WOT at about 30 mph I lose power, ruff idle, CEL with the following codes: p0300, p0303, p0305. A few hours later, and after clearing the codes, the car will drive like nothing ever happened. I drove the car for a week without any problem as long as I didn't hit WOT. Yesterday morning I Hit WOT just to see if the problem was still there, and just as I thought, the problem came back, same symptoms and same codes. Fortunately, I was still able to drive to work and park the car. Eight hours later car started fine no problem at all.
nyclad is offline   Reply With Quote
Old 11-10-2009, 09:42 AM   #2 (permalink)
Date registered: Jun 2005
Vehicle: 2003 E320 - wife's car now; 07 Porsche Boxster S - my car!!
You need a scanner that can read the freeze frame data to see the conditions that were existing when the CEL was set. These misfire codes can be set for many reasons, i.e., air/fuel ratio, ignition faults, mechanical, etc. The first thing you may want to do is check all the vacuum lines to make sure you do have any leaks/defects.
Regards,
paul...
paulv is offline   Reply With Quote
Old 11-19-2009, 10:23 PM   #3 (permalink)
Vehicle: 2003 E320
Thanks for responding Paul, i'll check on the weekend.
Thanks!
Old 12-11-2009, 08:30 AM   #4 (permalink)
Vehicle: 2003 E320
Turned out to be the aftermarket crankshaft position sensor I purchased on eBay a few months ago for $35.00
Sunday the car wouldn’t start at all, cranked normally but wouldn’t turn over. So I used my OBD II scanner got the code P0335 (Crankshaft position sensor) replaced it with a OEM CPS from the dealer, and the car started right up, even better than before. Took the car for a test drive at WOT no more misfire or check engine light.
Old 12-11-2009, 09:26 AM   #5 (permalink)
ohlord's Avatar
Vehicle: 1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, 94 Subaru Wagon ,1988 300E ,more....
OEM
cps at Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips
About 60 bucks. How much did the dealer rip you after being ripped bargain hunting on ebay?
Cognomen derived from
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz
My friends all drive Porsches
I must make amends
Worked hard all my lifetime
no help from my friends
So Lord, won't you buy me
a Mercedes Benz.
That's it.
ohlord
"Follow Peace,center Life"
"17mm SPECIAL SPARK BOOT TOOL"
Old 12-11-2009, 09:38 PM   #6 (permalink)
Vehicle: 2003 E320
Unhappy
$121.32
Check Engine light comes on during Smog test and reading codes - no codes found 1996s320 W140 S-Class 11 06-15-2009 09:37 AM
How do I retrieve Error Codes?? Check Engine light on Saul_Goode W124 E,CE,D,TD Class 2 11-17-2006 02:03 PM
Check Engine Light w/Error Codes 1999 C280 phidelt0135 W202 C-Class 3 01-09-2006 03:13 PM
Check Engine Light On, No Error Code dko888 W220 S-Class 14 12-22-2005 03:48 PM
Error Codes/Check Engine Electrical jason59 W210 E-Class 1 07-03-2005 06:14 AM
