DIY Front Brake Pad Replacement, 2006 E350 - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 10-31-2009, 12:01 PM Thread Starter
Date registered: Mar 2009
Vehicle: 2006 E350
Last weekend I replaced the front brake pads on my 2006 E350. Step-by-step instructions including photos are now up on my blog:
Dave Barnhart’s Mercedes-Benz E350 Pages Blog Archive Replacing Front Brake Pads
Dave Barnhart
Phoenix, AZ
2006 E350
Past Mercedes:
1993 300E
1984 300D
My E350 Blog
My 300E Website
dbarnhart is offline
post #2 of 25 (permalink) Old 11-01-2009, 06:07 PM
Date registered: Jul 2005
Quoted: 1088 Post(s)
Nice job.
One question, I thought once the the connector is unplugged from the SBS pump the pump
can not pressurize the system making it safe to work on. Now I am not sure based on what
you posted in the blog.
Noodles is offline
post #3 of 25 (permalink) Old 11-01-2009, 07:56 PM Thread Starter
Vehicle: 2006 E350
You're Right
It is theoretically possible that you could just unplug the SBC. I'm following the advice given to me my my mechanic who works on these all the time.
I speculate that if you just unplugged the SBC and then opened a door, the onboard computer would store one or more fault codes because it was unable to activate the SBC.
Dave Barnhart
Phoenix, AZ
2006 E350
Past Mercedes:
1993 300E
1984 300D
My E350 Blog
My 300E Website
post #4 of 25 (permalink) Old 11-01-2009, 11:42 PM
That makes sense. That code can't be cleared with most ODB II scanners.
I have access to a Solus scan tool and it would clear that code.
Hopefully I will have the SDS compact system up and running in a week.
Noodles is offline
post #5 of 25 (permalink) Old 11-03-2009, 02:11 PM
Date registered: Mar 2008
HI just would like to add my 2cents and maybe my 2005 e320 is not the same,,but be aware,,when i did my brake bleed job with similar precautions,,i forgot all about the inside button in the ceiling console that turns off the tow away alarm,,do disarm this before jacking your car,or you will find yourself doing this long job while listening to an earpiercing aggravating alarm,you should figure it out before you have the pads out,lol,,but just a warning,,,have a great day
lugerstew is offline
post #6 of 25 (permalink) Old 11-04-2009, 07:19 PM
Date registered: Jul 2009
this is great, would it work on 2004 e500 4 matic?
ajmal21 is offline
post #7 of 25 (permalink) Old 11-04-2009, 11:27 PM
It should work.
Noodles is offline
post #8 of 25 (permalink) Old 11-05-2009, 06:43 AM
vettdvr's Avatar
Date registered: Mar 2007
Vehicle: E500
Good procedures. I did see a difference in the 2003 vs the one in the procedure. For the 2003 bolt / caliper removal isn't required. There are two spring pins that are punched out, then caliper piston compressed enough to all the pads to be pulled out with the caliper installed.
ID:	270508   Click image for larger version
vettdvr is offline
post #9 of 25 (permalink) Old 11-05-2009, 12:22 PM Thread Starter
Vehicle: 2006 E350
Completely different from my '06 but a match to what's described in the Service CD.
Dave Barnhart
Phoenix, AZ
2006 E350
Past Mercedes:
1993 300E
1984 300D
My E350 Blog
My 300E Website
post #10 of 25 (permalink) Old 01-20-2010, 03:59 PM
Date registered: Jan 2010
Nice Job Dave!!! Thanks....I'll let you know how it works...does the same process work for the rear?
dlink is offline
    DIY Procedure for Brake Pad Replacement? Paul S8 ML350 W164 M-Class 29 04-21-2015 04:05 AM
    Photo DIY- Front Brake Pad Replacement G-AMG W202 C-Class 2 10-30-2011 07:36 PM
    DIY Front brake pad replacement on c230k sport sedan part 2 ohhmickaay W203 C-Class 17 07-28-2009 07:50 PM
    DIY Front brake pad replacement on c230k sport sedan part 1 ohhmickaay W203 C-Class 11 04-02-2008 03:47 PM
    any good diy on brake pad and rotor replacement? DETANE W163 M-Class 2 05-16-2007 03:48 PM
