How to check oil level - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 10-05-2009, 05:50 PM   #1 (permalink)
Date registered: Oct 2009
I believe that you check oil with the electronic sensor, but is there a dipstick or not?
jpendergrass1 is offline   Reply With Quote
Old 10-05-2009, 06:42 PM   #2 (permalink)
cagalbraith's Avatar
Date registered: Aug 2003
Vehicle: 2005 E320 Sedan
There is a dipstick available as parts. The engine does not come with one.
cagalbraith is offline   Reply With Quote
Old 10-05-2009, 07:01 PM   #3 (permalink)
Thanks for the response. So after purchasing, can it be installed easily or is it a job for the dealer?
Old 10-05-2009, 07:15 PM   #4 (permalink)
abiazis's Avatar
Date registered: Jul 2009
Vehicle: 2005 silver/black SL 65 AMG
Dipstick explanation from MB dealer
I was advised that the dipstick that you could buy, for about $ 60.00, was not permanent, but a shop tool only.
The reading of the stick is also a bit different, as the markings on stick are compared to a chart to determine oil level reading, depending on car's engine.
So....you could check the oil periodically, but stick stays in your garage or possibly in the trunk I suppose.
abiazis is offline   Reply With Quote
Old 10-06-2009, 01:55 PM   #5 (permalink)
drivbiwire's Avatar
Date registered: Mar 2006
Vehicle: 2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
Use the instrument cluster as intended. It is EXTREMELY accurate and the sump probe measures actual oil level at 1 millimeter increments. I can assure you that no dipstick can read at that level of accuracy...
drivbiwire is offline   Reply With Quote
Old 10-06-2009, 02:06 PM   #6 (permalink)
Date registered: Apr 2008
? my 06 e350 4matic has a dipstick in the engine bay and there is no way for me to check it via the IC
ThE GrEAt OnE is offline   Reply With Quote
Old 10-06-2009, 08:23 PM   #7 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI
Correct, when M272 (350) replaced M112 (320) in the W211, dipsticks returned.
I feel the same way, as the OM642 (GL) has dipstick, which the OM648 (E-class) doesn't, and I'd prefer the dashboard readout.
This is a REALLY TINY issue, with the dashboard readout the better solution.
Kent Christensen
Albuquerque
'07 GL320CDI
Old 10-07-2009, 12:03 AM   #8 (permalink)
Date registered: Jul 2005
Vehicle: 99 ML430, 90 300E, 05 E500 4matic Wagon
I got use to not having the dipstick. After a round of fluid changes I checked via the
dash and the special tool. I have total faith in the onboard oil level readings. Now I like it.
And yest the "special tool" dipstick is $60.
Noodles is offline   Reply With Quote
Bookmarks
oil level check zft325 W210 E-Class 3 08-02-2009 06:45 PM
Check Oil Level? rhines4 W210 E-Class 6 01-04-2009 09:07 PM
oil level check 515 W211 E-Class 5 12-26-2007 07:27 PM
Check engine electronics, Check oil level.+ others bondale W210 E-Class 5 11-10-2006 12:02 AM
