what type of Mobil 1 for E320CDI - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 09-05-2009, 04:28 PM Thread Starter
lws1's Avatar
Date registered: Sep 2009
Exclamation what type of Mobil 1 for E320CDI
Hello. I am considering buy a 2005 E320 CDI and am wondering what type of Mobil 1 (weight) would work here. I live in Miami, FL. I usually buy it for my mechanic and have 3 cases of whatever I use for my Lexus. Thanks!
lws1 is offline
post #2 of 13 (permalink) Old 09-05-2009, 04:42 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
Mobil 1 ESP 5W-40
Mobil Delvac 1 ESP 5W-40
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
post #3 of 13 (permalink) Old 09-05-2009, 05:49 PM
drivbiwire's Avatar
Date registered: Mar 2006
Vehicle: 2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
2005 E320 CDI can use the following:
Mobil 1 0w40 (MB229.5)
Mobil 1 5w40 ESP (MB229.51)
Mobil 1 5w40 Turbo Diesel Truck (MB228.31 = MB Heavy duty diesel truck rating with DPF and SCR)
Mobil Delvac 1 5w40 ESP (MB228.31 = MB Heavy duty Diesel truck rating with DPF and SCR)
Shell Rotella Synthetic 5w40 (MB228.31)
In Florida, as long as it is 0w40 or 5w40 you should be good to go. DO NOT use ANY oil that is 0w30 or 5w30 in that engine!
drivbiwire is offline
post #4 of 13 (permalink) Old 09-05-2009, 09:07 PM
Date registered: Aug 2009
Vehicle: 2005 E320 CDI, 1992 300TE, 1999 Porsche 911 Cabriolet
Post Certain motor oils allow the maximum range
In 2005, the mercedes maintenance system (MMS) for determining your range requests what oil is used (on the dashboard interface). The maximum range on a US 2005 E320 CDI is with 229.5 or 229.51 oils (12,500 miles??).
Another writer supplied this nice chart to identify all oils worldwide with their ratings,
http://www.whnet.com/4x4/oil.html
Mobil 1 is there several times.
After I wrestled with this question, I went to the dealer and they sold me Mobil 1 ESP-M 5W-40 and said the '-M' was for Mercedes. The prices seemed reasonable for the oil and filter (prettty high at Walmart too).
The 229.51 oils are for later Diesels with the particulate filter and tougher requirements. One key to note is the 'fleece' oil filter. I'm not sure when this becomes important so I bought that from the dealer also. The new one didn't look fleece but I'm not sure it wasn't.
ptkacik is offline
post #5 of 13 (permalink) Old 09-06-2009, 04:45 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Fleece filters are for gasoline engines.
Diesel Benz is offline
post #6 of 13 (permalink) Old 09-06-2009, 04:55 PM
Fleece filters in Diesels
Per the above web page oil info:
"For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters), 229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils."
All of the passenger diesel car engines from the A180 CDI to the S400 CDI are designated with the 600 series engine number so I'm still not sure whether or not fleece filters are needed. However, diesel particulate filters came on after 2005 model year.
ptkacik is offline
post #7 of 13 (permalink) Old 09-07-2009, 05:45 PM
doxland's Avatar
Date registered: Aug 2007
About this fleece filter
I've been to he dealers and asked them for fleece filter for our 2005 E320 CDI they and told me there is no such thing.
Anyone got a part # or more info; must be a breakdown in communication somewhere
Thanks
2005 E320 CDI
65,000 miles
doxland is offline
post #8 of 13 (permalink) Old 09-09-2009, 03:35 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Thanks
The "breakdown" has occurred wherever you read there's a fleece filter for the E320CDI.
There isn't. Dealer is correct.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #9 of 13 (permalink) Old 09-10-2009, 09:44 AM
Date registered: Jul 2009
Vehicle: '13 E350 BTC, '06 E320 CDI
Quoted: 6 Post(s)
Thanks
Here are the part numbers you requested for the filters (see page 14):
http://www.startekinfo.com/StarTek/o...stedDocId=9511
As noted in the attached document, a fleece filter is not mandatory for 2004 or older vehicles. It does appear to be a requirement starting in 2005.
Mike
Werkstattmeister is offline
post #10 of 13 (permalink) Old 09-10-2009, 12:23 PM
Quoted: 35 Post(s)
Mike
Have you seen how the 642 and 648 engine filters look like?
It is pretty odd though that an MB document from 2007 is this inaccurate.
    05 E320CDI should I or shouldn't I? lws1 General Mercedes-Benz 1 09-05-2009 03:45 PM
    Transfer case fluid ATF type 3 or type 5 bavenda W163 M-Class 8 03-23-2008 07:03 AM
    Can't decide: SL-type or 171-type front grille tmfoo R170 SLK-Class 29 11-07-2007 05:14 PM
    E320CDI Exleo General Mercedes-Benz 4 09-06-2005 03:31 PM
    Spring type and Shock type? JD W163 M-Class 0 04-17-2002 02:04 PM
