Water not draining - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 09-01-2009, 08:51 AM Thread Starter
Date registered: Aug 2009
Water not draining
I have a 2004 E500 and I noticted water now builds up in the area where the wiper arms are located. I removed wiper arms and tried to remove the cover by removing the plastic screws, but they only turned.
How can I remove this plastic cover? Any help would be appreciated.
Thank you
ehil500 is offline
post #2 of 12 (permalink) Old 09-01-2009, 09:49 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
You should actually get to the drain pipe bottom part to open the drain pipes. There is a bulletin describing the issue.
If you want to remove the cover, find the DIY guide on changing the heat exchanger shutoff valve describing this task too.
Diesel Benz is offline
post #3 of 12 (permalink) Old 09-01-2009, 10:06 AM Thread Starter
Diesel Benz,
Thank you
Would you know where I can find the bulletin and DIY guide for this item?
thanks
ehil500 is offline
post #4 of 12 (permalink) Old 09-01-2009, 10:18 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
Thank you
I believe that these are not screws, but removable expanding clips (item 5?) Pull them out with pliers to detach the 'water collector'. But it must be easier to clear the blockage as DB advises.
Name:	E500 wiper 1.jpg
ID:	257171   Click image for larger version
Name:	E500 wiper 2.jpg
keyhole is offline
post #5 of 12 (permalink) Old 09-01-2009, 10:21 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 206 Post(s)
MBUSA released Service Campaign 2007010002 JAN07 addressing water drains in front wheel housings not draining properly for the 211 MY03-06 and 219 (CLS) MY06. Service Campaigns do not expire therefore they are covered at no cost even out of warranty.
Particular to your 04 e500 (211.070) if you are within VIN range A008400–A725352 you are eligible for repair. Confirm by having your dealer check VMI (vehicle master inquiry).
Here is the link DB suggested: DIY: Installing a new Changeover/Heater Control Valve - MBWorld.org Forums
konigstiger is offline
post #6 of 12 (permalink) Old 09-01-2009, 10:31 AM Thread Starter
Everybody - thanks again....
ehil500 is offline
post #7 of 12 (permalink) Old 09-04-2009, 01:04 AM
Bimbis's Avatar
Date registered: Dec 2006
Vehicle: Formerly a 1990 200E; then a 2003 E320; and now a 2010 E350 P1, P2, Wheel pkg & folding rear seats
I had a similar problem once. I was able to reach the rubber hose just below the windscreen limits in the engine compartment. All I did was squeeze & release the hose repeatedly to get the water moving back and forth and the 'blockage' cleared up. It turned out to be just some dirt in the hose. But I didn't have to remove the wipers, etc. I flushed it with some clean water and I've had no problems since.
Bimbis is offline
post #8 of 12 (permalink) Old 09-04-2009, 07:37 AM Thread Starter
Windscreen?
Bimbis,
Sounds interesting and easy possible opition. But I am not familiar with "the windscreen". Is this hose on the side of the firewall?
thanks.
ehil500 is offline
post #9 of 12 (permalink) Old 09-04-2009, 10:48 AM
keyhole's Avatar
Quoted: 381 Post(s)
Bimbis,
As you have not completed your location/vehicle details with the UserCP ^^^^ we do not know whether to write US or UK English. Over this side of the pond the windshield is known as a windscreen, the hood is called a bonnet, the fender is called a wing, and the trunk is called a boot.
Hope that helps
keyhole is offline
post #10 of 12 (permalink) Old 09-04-2009, 12:03 PM
Bimbis's Avatar
Bimbis,
thanks.
I've attached 2 pics here taken from my (not too clean) car.
Both show the same area in the engine bay but the 2nd is a close up.
I was standing beside the car on the passenger side (left hand drive) looking into the engine bay.
The hose is actually in the center of the pics. Not visible in the first pic which I attached just to give an idea of the general area.
You can however see it in the second pic in the center of the pic circled by the yellow line and looking like a black tube. It can be squeezed gently to move the water back and forth until the dirt is free. The exit is behind the front wheel in the wheel arch.
Hope this helps
ID:	257641   Click image for larger version
Bimbis is offline
    Battery Draining..HELP adamcrockett W202 C-Class 3 09-16-2009 05:32 PM
    Battery Draining cal45fan W163 M-Class 6 10-08-2008 11:51 PM
    Battery draining itself white500se W116 S, SE, SEL, SD Class 10 09-04-2006 10:44 PM
    Draining Radiator lancer W123 E,CE,D,CD,TD,TE Class 5 06-10-2005 03:15 PM
    Something Draining the Battery? JonnyML500 W163 M-Class 11 11-13-2002 07:33 PM
