Gas cap loose, Service engine light - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-11-2009, 06:06 PM Thread Starter
Date registered: Apr 2005
Vehicle: 00 E430 Sport, 04 E500 4matic Sport
Was just at the dealer because my front passenger side airmatic shock failed and the loose gas cap warning, service engine light was on. I just purchased this car about a month ago, luckily it has the extended warranty so everything was covered. The service advisor said that they checked the gas cap and it was fine. The code for the service engine was P2013...major leak in the purge system. They say that they performed a fuel tank leak test and it was ok. He then said that it was a software problem and it was taken care of. Guess what, still have the same problem! Any ideas what it could be? I figured it would be a good idea to make a couple of suggestions to him when I bring it back. Thanks!!
sel126 is offline
post #2 of 6 (permalink) Old 08-11-2009, 06:23 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Your profile states you have a 2000 E430 and this is the W211 forum ( 2003+ E-Class except for the wagon). In any event, a loose gas filler cap is more likely to cause a Check Engine Light on a W210 than what you are experiencing. The gaskets fail and this is a common complaint. Please clarify what car your are referring to because the answers you receive will depend on it.
Musikmann is offline
post #3 of 6 (permalink) Old 08-11-2009, 06:47 PM Thread Starter
Sorry about the car mix-up, like I said before I just got this car about a month ago. I have a 2000 W210 E430 Sport, and I just bought a 2004 W211 E500 4matic sport. My problem is with the W211.
sel126 is offline
post #4 of 6 (permalink) Old 08-12-2009, 10:17 AM
Date registered: Jan 2009
Vehicle: 95SS(165k) 06CDI(SOLD) 2014 GLK250
its very hard to find a problem through just reading your statements
you have a warranty let the dealer fix
BlackOpalCDI is offline
post #5 of 6 (permalink) Old 08-12-2009, 10:51 AM Thread Starter
I'm making an appointment to bring the car in this week. I'll post the outcome when I get it back.
Thanks,
Scott
sel126 is offline
post #6 of 6 (permalink) Old 08-16-2009, 07:09 PM Thread Starter
Brought the car in on Sat. and a vacuum test was performed, and found a purge valve faulty. So it was replaced and hopefully the problem has been solved. The whole thing took about two hours.
sel126 is offline
    Check Engine Light Due to Loose Gas Cap FixMyBenz W163 M-Class 6 04-17-2009 07:59 AM
    Check engine light on due to Tank Cap Loose gahmed General Mercedes-Benz 21 07-27-2007 11:19 AM
    Check Engine due to Gas Tank Cap loose.. gahmed W220 S-Class 1 07-26-2007 11:25 AM
    Check engine light, result of loose gas cap JLuecht210 W211 E-Class 3 07-27-2004 09:54 PM
    "Check Engine" light came on! First thing that came to mind was a loose gas cap, but it was not .... Beng R170 SLK-Class 6 02-13-2002 09:53 AM
