battery e320 2003 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-06-2009, 05:14 AM Thread Starter
Date registered: Mar 2009
battery e320 2003
i have not used my car for two months, now battery is dead as a nail, nothing works, can't even get the key to turn, i cannot open the trunk to get to the battery, is there a way to jump start or change the aux-battery, if so where is the aux battery.
any suggestions, thanks
singleinc is offline
post #2 of 11 (permalink) Old 03-06-2009, 05:21 AM
If you can get into the engine bay there are /is normally a place you can hook up a charger as in the factory one near the fusebox and there is also the starter motor and the alternator which definitely have a [if you can reach them] a positive terminal .Starter for a jumpstart or even to get power to the battery so you can open the boot,alternator for the same except do not jump start.ok? Kevman
kevman is offline
post #3 of 11 (permalink) Old 03-06-2009, 06:35 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
I would open the trunk with the mechanical key (the metal blade hidden into the plastic key) and charge the battery.
The AUX battery is isolated with a relay, of course you can find wires from the engine bay that are connected to the main battery at the trunk.
Diesel Benz is online now
post #4 of 11 (permalink) Old 03-06-2009, 08:01 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
I worked on the injectors on my cdi and believe me, there no big cable in site where you can hook up the jumper. It is W210 that has a post for jump start, but not W211.
As DB said the blade key suppose to open the trunk, otherwise I would put small charger on fuse rail to charge the car enough to open the doors and than replace the big battery
Strange that the battery went flat in 2 months. We had our older MB parked several times for 5 weeks and they always started without jump.
Kajtek1 is offline
post #5 of 11 (permalink) Old 03-06-2009, 04:13 PM
Date registered: Oct 2004
Vehicle: 2005 E220T CDI Avantgarde
There ARE posts in the engine bay (passenger side, by the interior airfilter box (at least my S211 has them)), and I do believe Diesel Benz is correct in saying they can be used for a jump start or charging, but I think the manual recommends connecting directly to the battery. Note, the manual states that the engine bay posts should NEVER be used for providing jump starts to other cars.
I'd go with Diesel Benz's advice. use the mechanical key to open the trunk and hook up a car electronics safe charger (which will control voltage spikes, have no sparking, and never go above 16V. I use a Swedish made CTEK 3600 myself) to the battery posts and charge the battery. The battery might need to be replaced if it can't hold a charge, though. In any case I'd be careful, if you jump start and have bad luck or do something wrong, it can cost quite a bit of money to replace MB branded black boxes...
E class interactive Owners Manual, Jump Starting: http://www4.mercedes-benz.com/e/cars...d13e47538.html
E class interactive Owners Manual, charging the battery: http://www4.mercedes-benz.com/e/cars...d13e46908.html (with the charger I use it's not necessary to remove, or even disconnect, the battery from the vehicle. Which is why I like it.)
snugglecola is offline
post #6 of 11 (permalink) Old 03-07-2009, 12:20 AM
Quoted: 37 Post(s)
My W211 does not have the jump start poles at the engine bay. I understand that all Wagons have those (do they assume wagons having cargo at the trunk ).
Some sedan owners claim they have the charge pole at the engine bay too. I'd really like to see a photo from a sedan. Or could it be on the smaller engines only where there is more room. Even EPC shows some of the parts for the jump start pole that definitely do not exist in my W211.
The on-line manual is "only" for current models that are a bit different because no AUX battery etc. It anyway shows the pole only for the wagon, for the sedan they advice to connect to the battery at the trunk.
post #7 of 11 (permalink) Old 03-07-2009, 03:33 AM
I think you're right. Taking a closer look, it certainly does seem like only the wagons have the jump start posts in the engine bay. I don't see a logical reason for this difference in design though, but I'm sure it's something. I don't think MB would put the posts in the engine bay on the wagons, and not in the sedans (W211), for no specific reason?
I checked the owners manual for my pre-facelift car to compare with the on-line manual (written for the facelifted cars), and the instructions for charging the battery or jump starting seem to be the same regardless of the design differences between the cars. The "old" manual describes the engine bay posts only for the wagons (S211), as well.
post #8 of 11 (permalink) Old 03-07-2009, 12:21 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
There is always free Road-Aid on a jump...1800formercedes
Peter Guenther is offline
post #9 of 11 (permalink) Old 09-17-2010, 10:58 PM
Date registered: Nov 2008
I took out my 2003 E320 blower motor filter under the hood. I found out there is a small battery. I think we might charge the car from there.
ewong1 is offline
post #10 of 11 (permalink) Old 09-18-2010, 02:23 AM
Quoted: 37 Post(s)
Charge the car or the battery? You can charge the AUX battery but it would not be connected to the main battery at the trunk and the main battery would not get charged from the front (when ignition is off, which should be the case if you try to charge the battery).
There are connectors at the front that allow charging the main battery but none that was intended for this (or jump starting), that is on a sedan model.
    2003 E320 battery problem minalepree24 General Mercedes-Benz 7 11-02-2009 01:33 PM
    Should I buy a 2003 E320 or 2004 e320? nprakash21 W211 E-Class 5 10-27-2007 12:31 PM
    car purchase: 2003 E320 or 2002 E320 (W210)? ProV1x W211 E-Class 3 03-21-2007 12:04 PM
    car purchase: 2003 E320 or 2002 E320 (W210)? ProV1x W210 E-Class 5 01-08-2007 02:16 PM
    2003 E320 OEM 16" => 1994 E320 with HUB CENTRIC SPACERS melon_stunner The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-14-2004 08:02 AM
