Secondary battery? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 02-04-2009, 12:43 PM Thread Starter
Date registered: Feb 2004
Vehicle: 1998 E320
Secondary battery?
My dealership tells me my 2005 E320 is due for a new secondary battery which is in the engine compartment. They quoted me $270 for replacement. Anyone know what that battery is and if it can be had from other than the dealer?
Also, how do I get to my cabin filters to replace them?
jimdvan is offline
post #2 of 8 (permalink) Old 02-04-2009, 01:08 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
The cabin filter is slide into the lid that covers the secondary battery. It is like additional 15 seconds to replace it during the main job so expect like $75 labor charge.
Check other topics for recommendation. To my knowledge the battery can be replaced with $49 motorcycle battery, but the "star-marked only parts" lobby is pretty strong here.
Kajtek1 is offline
post #3 of 8 (permalink) Old 02-04-2009, 02:58 PM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 215 Post(s)
Originally Posted by jimdvan View Post
My dealership tells me my 2005 E320 is due for a new secondary battery which is in the engine compartment. They quoted me $270 for replacement. Anyone know what that battery is and if it can be had from other than the dealer? Also, how do I get to my cabin filters to replace them?
Read this entire link for DIY battery cost
Red battery message ( Visit workshop) - MBWorld.org Forums
This link covers DIY replacement
http://www.benzworld.org/forums/w211...ml#post3288287
konigstiger is offline
post #4 of 8 (permalink) Old 02-04-2009, 04:45 PM
Date registered: Nov 2008
Vehicle: 2006 E500 - Flint Grey
Quoted: 2 Post(s)
As long as the specs are the same as the current battery you'd be fine ... Have you priced the battery from the parts department? Calling around a few dealers you may find it cheaper ..
dvmak is offline
post #5 of 8 (permalink) Old 02-04-2009, 06:51 PM Thread Starter
Vehicle: 1998 E320
Thanks guys. Very helpfull. I'm ready to take it on.
jimdvan is offline
post #6 of 8 (permalink) Old 10-29-2009, 01:29 PM
Date registered: Oct 2009
Thumbs up Battery Warning Indicator with visit Workshop on E320
Thanks to all the forum members, I had in dash indicator about the Battery Symbol and visit workshop sign. I followed the discussions and went to batteriesplus in Lewisville TX, the folks there replaced the battery [ the auxiliary one [ under the hood - below the air filter]. The warning is gone once we replaced the aux battery. The battery was 6 yrs old!
Appreciate the discussion.
Shridhar
E320 2003 Sports
http://www.batteriesplus.com/p-32749...t-battery.aspx
Shridhar is offline
post #7 of 8 (permalink) Old 10-29-2009, 02:06 PM
Date registered: Sep 2008
Vehicle: 2006 Merc E320 cdi
Quoted: 51 Post(s)
I did my battery yesterday and it was a cinch to get the old battery out. I used the battery from batteries plus.. I just kept the connectors apart and did not allow them to touch anything metal (and all of the metal is covered up by something in that part of the car). I had to align those little screw bolts and that took up all of the time. Otherwise, I could have replaced the battery in under 10 minutes.
This might not be the preferred way to go (not disconnecting the battery in the trunk) but there were no sparks or anything..
The dealer is definitely smoking something when they want $300-400 to replace this battery.. Battery cost was $69 in NC..
aeubank is offline
post #8 of 8 (permalink) Old 10-31-2009, 08:16 AM
Date registered: Dec 2006
I replaced mine about 6 months ago with one from Batteries Plus. It cost around $60. Just make sure the post are in the correct positions and the amp-hour rating is close to what the original one was (marked on the top).
I think mine was just a little less than the original. No problems with the swap and it saved me $200 from the high and mighty MB dealership!
ebbarnes is offline
    Secondary air injector steve e class limo W210 E-Class 5 12-20-2008 07:05 AM
    The secondary heating system mckellyb W126 S,SE,SEC,SEL,SD,SDL Class 2 12-15-2008 07:46 PM
    Secondary Air Pump Jeff522 W210 E-Class 0 10-14-2007 09:00 AM
    Secondary Cat Delete X55 W210 E50 AMG, E55 AMG 10 08-03-2007 09:10 AM
    secondary vacuum reservoir DOUGLAS MARTIN W123 E,CE,D,CD,TD,TE Class 3 10-26-2004 05:29 PM
