open hood warning? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 02-02-2009, 09:07 PM Thread Starter
Vehicle: 2011 E350 Bluetec, 2004 E500, 96 SL500, 90 300ce
Send a message via AIM to playeraww
open hood warning?
2004 E500 50k miles just started this weekend. Everytime I drive the car the open hood warning comes on. You can turn it off while driving but once you stop at a light and start again the light comes back on. I have opened the hood and closed it several times with no success. Anyone even know where the sensor is?
playeraww is offline
post #2 of 16 (permalink) Old 02-02-2009, 09:31 PM
Kajtek1's Avatar
Quoted: 1167 Post(s)
under the hood?
sorry, couldn't resist
Kajtek1 is offline
post #3 of 16 (permalink) Old 02-02-2009, 11:11 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Well, the "hood open switch" would be under the hood. If I remember right, it is at the hood latch on the right side. There was recently another owner asking about the same issue, he/she did not come back to report if it was the switch or the plug loose or some wiring issue.
Diesel Benz is offline
post #4 of 16 (permalink) Old 02-03-2009, 12:00 PM
Date registered: Oct 2008
Quoted: 2 Post(s)
Send a message via Yahoo to NAPTOWNBENZ
Its an alarm switch located on the passenger side of the front support frame.
Shawn
Mercedes-Benz of Annapolis
www.getmercedesparts.com
NAPTOWNBENZ is offline
post #5 of 16 (permalink) Old 02-03-2009, 03:05 PM Thread Starter
Fixed it. The sensor switch is on the passenger side of the hood latch. The sensor fell down from its mounting enough to where when the hood was closed it could not contact the sensor. I pulled it back in place and all was good.
post #6 of 16 (permalink) Old 02-03-2009, 11:03 PM
Quoted: 35 Post(s)
Well, in my opinion that is the right side of the vehicle, on a RHD car the passenger would be at the other side.
Anyway, very good to hear this feedback, likely turns useful for others (note that I don't even have this switch in my car). Sounds likely that the previous case was the same even it the owner never reported back.
post #7 of 16 (permalink) Old 02-09-2009, 10:35 AM
gnma's Avatar
Date registered: Nov 2007
Vehicle: Supra Turbo, Maxima 6Spd, E500
Thank you for posting your findings. Great job!!
gnma is offline
post #8 of 16 (permalink) Old 02-03-2010, 09:47 AM
Date registered: Feb 2010
CLK350 2009 Hood Warning Message
The hood open sensor/switch for a CLK350, Model Year 2009 is built into the DRIVERS SIDE hood latch(there are 2 latches for the hood, one on the passenger, one on the driver's side).
Just thought I would add this if anyone is looking.
As a new owner, I might also add the hood release is UNDER THE DASH, to the right of the brake release, and has a red handle. Never would have tried to pull on it without reading the manual. I don't think it is labeled, but if it is, it isn't very clear.
zgreatwhite is offline
post #9 of 16 (permalink) Old 12-02-2010, 10:25 AM
Date registered: Nov 2009
Vehicle: 2004 E500, 2003 G500
Fixed mine several times
I have a 2004 E500 with the same problem. The first time I fixed it the sensor stayed in place for several months. Now it lasts a few minutes before it slips off the frame that is meant to house it. I don't really want to glue it in place but that seems like the next step.
Anyone have any brighter ideas?
HughJacks is offline
post #10 of 16 (permalink) Old 12-02-2010, 11:45 AM
grohgreg's Avatar
Date registered: Jul 2010
Vehicle: 1985 300CD Turbo coupe, 2006 E320 CDI sedan
Well, typically either the retainer clips are a part of the switch, or the switch fits into a retainer. Assuming yours is the latter, why not just replace the switch? Door switches run about $6-$7 bucks, I doubt a hood switch is much more.
//greg//
grohgreg is offline
    Hood Release Cable Broke...Can't Open Hood..Help! NRMl430 W163 M-Class 53 03-19-2015 09:41 AM
    Engine hood open warning light brent1777 W203 C-Class 4 12-29-2011 11:51 AM
    Dash Warning "Hood Open" dmj4 General Mercedes-Benz 2 12-20-2008 08:48 AM
    Hood Open Warning - Except it isn't wizwith W203 C-Class 6 04-19-2008 01:27 PM
    Door open warning tiggerfink R170 SLK-Class 4 12-11-2005 11:14 AM
