Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 09-05-2008, 09:22 PM   #1 (permalink)
ibparn's Avatar
Date registered: Apr 2005
Vehicle: 2003 E320
Post Puck and Tail - Help.....
I've got a 2003 E320 and I've been told (2) different stories from (2) different Benz dealers, one in Idaho and one in Southern California. The dealer in Idaho says I can't install the "Puck and Tail" to use to have Bluetooth. The dealer in California says no problem. I’ve read many of the threads and it appears that I should be able to connect the "Tail", connect my phone ( LG Chocolate) with some updates and be up and running. I’ve enclosed a picture of the connector beneath my arm rest with the question is this the plug that would connect to the tail. Any help would be appreciated.
Thanks
ibparn is offline   Reply With Quote
Old 09-06-2008, 12:30 AM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
Looks like you've taken too many parts out. There should be a connector at the left bottom area once the false door is removed. An RJ45 like (but 10 pin) connector. You can identify it also from wire colours (sorry but I did not go and find them but there are documents posted already).
Diesel Benz is offline   Reply With Quote
Old 09-06-2008, 09:28 AM   #3 (permalink)
ibparn's Avatar
Vehicle: 2003 E320
Thanks for the impute. This is how it looked when I purchased it, as far as the wiring..
Thanks again...
Old 09-07-2008, 07:21 PM   #4 (permalink)
Date registered: Feb 2007
Vehicle: 2003 E320 Obsidian Black Metallic
Even the same year (2003) has their differences. I have a 2003 E320 and my wiring looks nothing like this one. I can tell you that YES, you should be able to install the Puck and Tail but, you will still have to take it to Mercedes for them to code the system to recognize the Puck and Tail. It is basically to tell the system that you now have the Puck system. I did it on mine at Princeton Mercedes in NJ and is working like a charm. On my E320 the Console wiring looks nothing like yours and I know that the Antenna Connector Looked like a COAX Connector (not that you need it). Do you have pictures of the Tail you will use?
If it was exactly like mine I would have been able to help you easily cause I did it on mine and I opened that console several times but like I said, unfortunately is not.
Good Luck !
Handyovi is offline   Reply With Quote
Old 09-07-2008, 07:57 PM   #5 (permalink)
ibparn's Avatar
Vehicle: 2003 E320
There does look like another compartment below. I will investigate and let you know. Thanks for the tips and ideas...
Old 09-07-2008, 11:01 PM   #6 (permalink)
It does not have to be an MB workshop, anyone with SDS can do it. Of course all MB workshops can do it (or let's say have the equipment to do it ).
Paul's phone bulletins should show how the different connectors look like:
http://phdwebsite.powerpulse.cc/Phon...Sedan%2003.pdf
Old 09-09-2008, 08:41 PM   #7 (permalink)
ibparn's Avatar
Vehicle: 2003 E320
Found the right compartment and connection....
Now it's off to see if my LG VX8500 is compatible.
Thanks again...
Bluetooth "Puck with Tail" version coding problems jamsong W211 E-Class 21 11-17-2008 09:56 AM
2004 E55 IPhone bluetooth puck with tail works! Yacht Master W211 E55 AMG, E63 AMG 16 09-17-2008 03:05 AM
Bluetooth Puck ??? rparrish22 W209 New CLK Class 6 01-19-2008 03:01 PM
Anyone know how to get install docs puck with tail? DrBob Audio & Telematics Forum 1 07-24-2007 11:47 AM
Bluetooth puck D2k W208 CLK Class 2 05-28-2006 09:56 PM
