Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 08-31-2008, 06:46 AM   #1 (permalink)
Date registered: Mar 2003
Question Should I buy it?
My local MB dealer has a 2004 E320 with 34,000 miles on it. It comes with a MB Certified used car program that lasts through August 2010. They are asking 21,000. Is it worth it? Is the certified program any good? The car is black on black. Was traded in for a 2008.
Any major issues with this year? Any and all comments/advise welcome.
Thanks!!
1980 300SD - 114k and perfect
1982 240D - 218k No rust all stock
1989 560SEL - 148k Das boot
allandrussell is offline   Reply With Quote
Old 08-31-2008, 07:42 AM   #2 (permalink)
Date registered: Mar 2007
Vehicle: 2006 E500W4
As long as all 03 recall campaigns were performed, you are fine. The warranty program is a good thing, and should compensate for any missed TSB or recall. $21k is a good price for an 04 CPO. Check also whether you have the nav system or not. Mercedes are cars you get to increasingly appreciate with time. They are safe, comfortable and well thought through. Good luck!
ODEL
06 E500W4 everything except distronic
odel is offline   Reply With Quote
Old 08-31-2008, 11:09 AM   #3 (permalink)
Date registered: Dec 2007
I'm in the same position as you with regard to these cars; I'm buying my first one, and also trying to watch my budget.
With the caveat that I've never owned one, I'm getting the impression that you should try to avoid 2003-2005. Quality was apparently poor the first years and then began to improve 2005 on, with 2006 being "better" than 2005 and 2007 being "better" than 2006. My budget really comfortably allows a 2005-2006, but I'm going to stretch myself to a well maintained 2007, even if it means going a bit higher mileage.
It's exciting, isn't it . . .
grundig is offline   Reply With Quote
slk 350....to buy or not to buy OEM AMG Exhaust angeloti R171 SLK Class 0 06-23-2008 02:20 PM
Should I buy a S500 that has been a manufacture buy back? dmtza W220 S-Class 12 04-03-2008 09:48 PM
If I was to buy a parts car for you guys, would you buy? CharlesAFerg W140 S-Class 4 01-31-2007 05:04 AM
88 560sel with single valve tap..buy or no buy? IceBlue_1980_300TD W126 S,SE,SEC,SEL,SD,SDL Class 9 12-15-2005 12:48 PM
Advice needed on 1993 500SEC... to buy or not to buy? Guest (MBNZ) W220 S-Class 2 05-30-2002 08:23 PM
