Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 08-30-2008, 02:53 AM   #1 (permalink)
willy_manilly's Avatar
Date registered: Jan 2007
Question ESP, Check brakes and Speedtronic Malfunction after installing new wheels HELP
I just installed 19" wheels today and then i took it for a drive in the wet and it came up with Check Breaks, Speedtronic Malfunction and ESP Defective Malfunctions. Is there anything i can do about this? Do i have to reset the computer or something as i has 16" wheels on it before?
Thanks
My Cars:
Mercedes E270 CDI 04' - Pacific Blue Leather / Aragonite Blue - NAV - DIST - ROOF - 19" AMG RIMS
BMW X5 4.4 02' Black Leather / Titan Silver - NAV - FLOOR - 18" RIMS
willy_manilly is offline   Reply With Quote
Old 08-30-2008, 03:21 AM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
Which tyres do you have on the wheels? Is the diameter the same on all?
Diesel Benz is offline   Reply With Quote
Old 08-30-2008, 03:34 AM   #3 (permalink)
285/30/19 Rears
255/35/19 Fronts,
The set was purchased used, and the rears have about 20% tread and the fronts have about 70% tread.
All tyres are Michelin Pilot Sport
EDIT: I just went down to the garrage then and turned on the car and all the error messages have gone, but im not sure if they will come back, should i disconnect the battery and then wait half an hour then reconnect and see what happens?
Old 08-30-2008, 11:30 AM   #4 (permalink)
The front tyres are 1.1% bigger by diameter if I calculated correctly. The tread difference makes it about as much worse. If the message keeps away, ESP must have adapted to your current tyre size difference (I don't know how much it can tolerate).
By the way, pretty dangerous to have that low tyre tread at the rear while the fronts are good. The opposite would be safer.
Old 08-30-2008, 02:59 PM   #5 (permalink)
What do you mean by adapted?
Bleeding ESP Brakes gauthier613 W202 C-Class 0 05-25-2008 11:35 AM
Installing 19" wheels.... papinboo W210 E50 AMG, E55 AMG 6 11-26-2007 01:56 PM
Got 4 Malfunctions 1 BAD BURB W210 E50 AMG, E55 AMG 13 04-19-2007 11:18 PM
3 Malfunctions - ABS, BAS, ESP juntao W208 CLK Class 10 12-11-2006 01:03 PM
Installing New Brakes? GoSpeedRacerG00 W126 S,SE,SEC,SEL,SD,SDL Class 6 11-02-2004 01:03 PM
