Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 08-27-2008, 09:29 AM   #1 (permalink)
Date registered: Mar 2007
Wheels for E500 4MATIC
Hi,
Has anyone purchased wheels for w211 4MATIC's with TPMS? I was wondering if im able to buy offset wheels, like the E55, or if they all have to be the same exact size. I have a 4MATIC with TPMS and i wanted to know what i need to look into when purchasing rims/wheels. Thanks.
oo0hmx0oo is offline   Reply With Quote
Old 08-27-2008, 10:44 AM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
To my knowledge 4-Matic is having the same wheels what regular sedan.
AMG models have wider wheels and lowered suspension.
Kajtek1 is offline   Reply With Quote
Old 08-27-2008, 12:43 PM   #3 (permalink)
So then when searching for AMG wheels, i have to make sure that they're all the same size and NOT staggered. Is that correct? Thanks.
Old 08-27-2008, 01:45 PM   #4 (permalink)
henryt111's Avatar
Date registered: Nov 2002
Vehicle: 91 500SL 80K / 2003 E500 120K (Runs Perfect!)
As far As I understand ....the 4matic will ONLY work with a certain wheel, 17in ...I believe, AMG uses 18 and staggered are not an option ...
I have a friend who has a 2006 E350 and put AMG wheels on aftre about 200+ miles his
tranny coded ... he took the wheels off and put the orignals back on so that the warranty would cover the cost ...It was a royal pain for him... needless to say he sold the Monoblocks (18) staggered set he had ....
Get the rim guide from your service dept that shows what wheels will be supported ...
good luck !
henryt111 is offline   Reply With Quote
Old 08-27-2008, 04:46 PM   #5 (permalink)
Kajtek1's Avatar
Those things can be pretty complicated, so I can only say what I learned about the systems over the years.
4-Matic has traction control on all wheels. Difference in wheels speeds will trigger the system, what usually starts with cruise control dropping off.
Since getting 2 different tires turning at the same speeds is almost impossible, therefore staggered wheels are limited to 2 WD most of the time. Changing all 4 wheels to different size shouldn't make traction control problems as long as they don't rub anything. In ML section you will find posts, where members put wheels way bigger than OEM, but having all 4 the same don't cost problems.
2004 e500 4Matic BklynPlayboy W211 E-Class 2 05-30-2008 11:14 PM
Staged wheels in E500 4Matic verdugo The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 02-12-2006 10:53 AM
Can I use 18X8.5 wheels on 2004 E500 4Matic wagndr The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 12-20-2005 12:28 PM
2006 E500 4matic? cashking W211 E-Class 1 04-19-2005 10:28 PM
Mercedes E500 4Matic Baloo588 W211 E-Class 3 09-30-2002 06:23 AM
