Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 08-22-2008, 09:12 PM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 2000 Land cruiser 100 05 E280
engine oil
whats the best engine oil to use for my e280? thanks!
dags is offline   Reply With Quote
Old 08-23-2008, 10:35 AM   #2 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
We don't have the same oils available in the USA as you do wherever you are.
Kent Christensen
Albuquerque
How much engine oil to bring oil level from min to max? allerton W126 S,SE,SEC,SEL,SD,SDL Class 15 07-26-2006 06:50 AM
Oil Extreme - Engine oil additives anilasher General Mercedes-Benz 3 10-05-2004 09:54 PM
Someone Drained the Tranny oil instead of engine oil ae86pwr W163 M-Class 8 06-09-2004 09:00 PM
Do you have to add engine oil before FSS oil change??? 00 ML430 Bulldog W163 M-Class 2 02-07-2004 03:59 PM
My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 02:34 PM
