Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 07-24-2008, 09:32 PM   #1 (permalink)
Date registered: Sep 2007
Vehicle: 97 E420
Possible to play MP3 cd's on 03 E320?
Hello all, i was wondering it is possible to upgrade the stock (non navi) headuinto on an 03 e320 and allow it to read MP3 cd's? i've read about the engineering menu and all the secret commands and what not, but i was unable to deiscover if this was possible or not. thanks in advance
moelsaied88 is offline   Reply With Quote
Old 07-26-2008, 06:32 AM   #2 (permalink)
Vehicle: 97 E420
bump
Old 07-26-2008, 10:18 AM   #3 (permalink)
SPNJHockey's Avatar
Date registered: Jul 2007
Vehicle: 07 E350 4Matic w/P1 & Sport Pkg
Moe,
Do you have the second single-CD drive right above your radio (in addition to the 6-CD drive below the radio)?
Also, ck this thread over at MB World (didn't find anything on this forum):
http://www.benzworld.org/forums/w211...s-03-e320.html
David
SPNJHockey is offline   Reply With Quote
Old 07-26-2008, 12:18 PM   #4 (permalink)
Date registered: Jan 2007
You may want to try a head unit software update with MBUSA Special Tool (service disc) #W211589122200 – dealer net $12. Some have reported that they could play MP3 CDs through the single disc player after updating.
Power up head unit
Press "Audio" hardkey
Insert service disc (will start automatically)
Head unit will power off and then restart
Eject disc
If this does not work I would suggest changing out the AUDIO50 (cassette) with a COMAND headunit or install a 6-disc MP3 CD changer.
'06 CLS500: Iridium Silver/Black leather/ High Gloss Laurel wood trim; Electronic trunk closer; SIRIUS; VCS; 318 Trim pkg (wood/leather steering wheel & wood shift knob); 326 Premium pkg (multicontour/active ventilated seats, logic 7; MP3 6-disc changer; COMAND DVD nav; power rear sunshade); built 8/05, delivered 10/05.
konigstiger is offline   Reply With Quote
Old 07-26-2008, 04:45 PM   #5 (permalink)
Vehicle: 97 E420
i only have the single disc above the radio. no cd changer. can i get this cd from else where, such as an online download? or is it only available from dealer. also, do you know what other changes the update brings? thanks in advance (btw the link u sent is this same page over again)
Old 07-26-2008, 05:56 PM   #6 (permalink)
I would suggest contacting a local dealer. Update was released to resolve a number of conditions including those listed below however; some reported the ability to play MP3s in the single disc player after updating.
- CD player does not retain correct track info played prior to shut down
- Display locks up or freezes in any mode, various keys do not work
- CD skips or hesitates
- CD track or audio station info mismatch between head unit and display/status line/instrument cluster
- Audio muted before ignition turn off, mute not retained upon restart
Old 07-26-2008, 09:41 PM   #7 (permalink)
SPNJHockey's Avatar
...btw the link u sent is this same page over again)
Ck your PMs.
Old 08-19-2008, 04:29 PM   #8 (permalink)
Date registered: Mar 2008
Vehicle: 07 E 320 Bluetec- 07 SL55
hi i have a 07 E bluetec and with non navi radio and it plays MP3
i did nothing to the radio,no upgrade
udow is offline   Reply With Quote
Old 09-03-2008, 12:14 PM   #9 (permalink)
Date registered: Apr 2007
Vehicle: 2005 E500 4matic.
Originally Posted by konigstiger View Post
You may want to try a head unit software update with MBUSA Special Tool (service disc) #W211589122200 – dealer net $12....
Is there a way to tell if my car already has this update? I have a 2005 E500 4Matic.
cokenfries is offline   Reply With Quote
Old 09-03-2008, 06:13 PM   #10 (permalink)
Use the navigation display softkey to see if you can choose ETA. If not, you do not have the update.
MP3 CD's bocabenz W163 M-Class 13 05-16-2007 06:24 AM
playing mp3 cd's in the r171? Tom (Vancouver) R171 SLK Class 13 10-04-2005 06:05 PM
What are the top 3 CD's/tapes you play in your car? busters the boy! Off-Topic 30 09-10-2004 05:45 AM
DVD-Based Navigation doesn't play music CD's jklny W163 M-Class 12 10-02-2002 11:42 AM
SLK CD Changer doesn't play copy protected CD's? rage2 (Calgary) R170 SLK Class 7 05-20-2002 07:42 PM
