Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 07-24-2008, 01:37 PM   #1 (permalink)
Date registered: Oct 2007
Question Need Suspension Help
I have a 2005 Mercedes E320 and when I put new wheals on the car, the front end suspension raised up. Now I have noticed that it raised up so much that the outsides of the two front tires are wearing and the insides looks brand new. I need to reset the suspension on the car, but the new models no longer have a switch to turn it off and on. Can anyone help me?
itisasha is offline   Reply With Quote
Old 07-24-2008, 11:37 PM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
First, are you saying you don't have Airmatic suspension? Airmatic was available for the E320 even in the US with some sports package.
If you don't have Airmatic, there is not a lot of need to reset the steel springs or turn them on and off.
If you do have Airmatic, the springs do stretch out when the car is jacked (so do steel springs) but the car would level once you drive a bit.
Sounds more like you have an alignment issue.
Diesel Benz is online now   Reply With Quote
Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 3 07-28-2007 03:56 PM
Can you change the air suspension from a V-Class to Spring suspension? kimberly General Mercedes-Benz 2 11-16-2006 02:35 AM
Can you replace the self-leveling suspension with a regular suspension 300e_4matic W124 E,CE,D,TD Class 10 12-21-2005 12:14 PM
What is difference between normal suspension and super suspension Gatecrash R171 SLK Class 0 04-06-2004 09:10 AM
How much suspension travel is there on a SLK32 with OEM suspension; front & rear? Beng R170 SLK Class 1 01-23-2002 09:33 PM
