"E" Service Help - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 06-13-2008, 06:43 AM Thread Starter
jfamondone's Avatar
Date registered: Mar 2006
Vehicle: 2007 ML 350 Iridium Silver/ Ash (Sold)
Post "E" Service Help
Hello All,
Can you please give me a quick overview of the "E" service.
Thanks for your replies
jfamondone is offline
post #2 of 16 (permalink) Old 06-13-2008, 07:11 AM
The Workshop MB's Avatar
Date registered: Apr 2006
Vehicle: 1988 300 TE. 2001 ML 55AMG The Shop is Open!!!
This information is in your service/maintenanc booklet
Originally Posted by jfamondone View Post
Hello All,
What is your current mileage?
Happy Benzing!!!
The Workshop MB is offline
post #3 of 16 (permalink) Old 06-16-2008, 05:33 PM Thread Starter
jfamondone's Avatar
2003 E 320 "E" service 57,300 miles. Can you pleaes explain what this service is
Thanks in advance for your replies
post #4 of 16 (permalink) Old 06-17-2008, 02:28 AM
Date registered: Mar 2007
Vehicle: 2006 E500W4
Service E
According to maintenance booklet (see attachment) it is mainly and oil and filter change, with lots of visual inspection at $120/h labor rate. E being the 5th the letter of the alphabet, it indicates that about 5h will be required to perform the service. Hope this helps.
ODEL
06 E500W4 everything except distronic
odel is offline
post #5 of 16 (permalink) Old 06-17-2008, 06:44 PM
Date registered: Oct 2006
Wow, so basically your saying that it's a $500+ oil change!
Damn, I'm due for an E service as well and I only have 33,000 miles.
NVR ENUF is offline
post #6 of 16 (permalink) Old 06-17-2008, 08:02 PM
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
Thumbs up
Change the oil and filter yourself and get to know your Mercedes!!!
It's not that hard if you use the oil suction extractor.. you can do it all from the top of the car dressed in your Tux (like James Bond).
Go look at the oil change threads here and there...
Good Luck ,,,
: MBZ 280E, 260E, 300SD
MBZ 190E, E320W, CLK350
unitfreebie is offline
post #7 of 16 (permalink) Old 06-17-2008, 08:29 PM
I'd love to do it myself except my vehicle is still under warranty and I can bet if I don't take it to the stealership for maintenance, they'll prolly say my warranty is null & void!
Once the warranty is over, I'll definitely be doing oil and brakes myself!
NVR ENUF is offline
post #8 of 16 (permalink) Old 06-17-2008, 11:53 PM
Post 60,000 miles or BUST!!!
OH.... you have an extended warranty? Or is it just about up?
The 60, 000 miles service is a major service... all the fluids in the car should be changed including the transmission. Spark plugs changed.
Your car has the SBC brakes so it requires an annual brake fluid change, otherwise the copper in the lines will cause problems with the SBC valves.
I don't know when the radiator service went to 140,000 miles, but it should be left alone unless there is a leak. Of course the air conditioning should be check for correct pressure and top off with R134a if low.
All the above will take about 5 hours on the average ... I don't think Lexus is more different. If you plan to keep the car, then the service is worth it... otherwise....
Good Luck...
post #9 of 16 (permalink) Old 06-30-2008, 09:28 PM
Well, I just had the E service done to my car and the damage was $408. My MB rep said that there were some others things done too but was covered under the warranty. So I guess it could've been much more in costs. I know I have at least one more service before the warranty is up since I'm at 33k now.
NVR ENUF is offline
post #10 of 16 (permalink) Old 08-06-2009, 06:49 AM
Rashid Ahmad's Avatar
Date registered: May 2009
Vehicle: E280 - 2007 (W211)
well, my car is having 75,500KM on the clock & still showing Service "E" is due in 5XXX KM!!!!
Rashid Ahmad is offline
    What is the difference between Service "A" or "B" ? Mercedes Benz of Florida General Mercedes-Benz 0 05-09-2008 08:19 AM
    how to reset the service light "service exceeded 510 days" shuiyuan W210 E-Class 2 05-09-2008 02:43 AM
    Service "A" & "B" mbz4ever W163 M-Class 6 01-21-2003 08:07 PM
    What does service "A" and "B" usually cost at a MB dealer? mikeyCLK C208/A208 CLK-Class 5 01-15-2003 01:17 PM
