Bluetooth "Puck with Tail" version coding problems - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 03-15-2008, 02:56 AM Thread Starter
jamsong's Avatar
Vehicle: 2004 E320S4
I have an 04 E320 and I got the "CP Interface Kit with Bluetooth", part no: B 67 87 5855
I am able to pair with my wife's bluetooth phone (RAZR v3) but (predictably without version coding) I cannot hear on either side of the call and when I press "Phone" on the Comand system, it says, "Phone not installed"
I installed it which was very easy and then I took it to the dealer to be version coded.
I gave my service advisor a copy of the diagram of the Star Diagnosis of the Tele-Aid page with the "Portable cellular telephone" set to "Fitted" and asked them to do the same with my car.
I was not present when they did this so obviously, the phone was not still paired when the dealer did the version coding. Moreover, I was unable to pick up the car until after hours so I couldn't talk to a tech but I picked up the car and the bluetooth kit still does not work. I get the same "Phone not installed" message. Still got charged $56.25 for .5hrs of labor...
This is what my service invoice says:
"Checked and changed version coding within VTEL control module as per client request and found that vehicle not equipped with bluetooth control module."
So my question, am I missing anything? It seems like others just installed the device and then got their dealership service to change one setting in the Tele-aid.
Do I need to have the phone paired while it's being version coded?
Are there other settings that need to be changed on the Star Diagnosis?
I won't be able to talk to a service advisor or tech until Monday.
jamsong is offline
post #2 of 25 (permalink) Old 03-15-2008, 06:43 PM
Yacht Master's Avatar
Date registered: Nov 2006
Vehicle: E-ZGO 53 HP., 99 E 430 sport, 04 E55 AMG, 2008 Tahoe LTZ Sold Porsche to Brother
Quoted: 47 Post(s)
The tech needs yet one more shot at it.
Call the SA and ask him for a purchase order to reimburse you for training their tech.
It really is so simple a caveman could do it. In less than 5 min.
Yacht Master is offline
post #3 of 25 (permalink) Old 03-15-2008, 11:05 PM Thread Starter
jamsong's Avatar
Do you suppose that the tech just screwed up or put the settings back to default?
I'm thinking the tech didn't follow my instructions and just programmed the "Bluetooth System" to "Fitted" and left the "Portable Cellular Telephone" to "Not Fitted" on the Star Tele-aid page.
Hopefully, I'll get this answer on Monday.
Also, are you saying, definitively, that there is nothing more to do than what I described?
Thanks for the reply.
jamsong is offline
post #4 of 25 (permalink) Old 03-16-2008, 12:20 AM
Date registered: Mar 2007
Vehicle: ML350
that is most likely the issue... remember that the puck with tail module is a newer and not very common so there may be one guy in service who has familiarity with it.. its not their fault, there is simply too much for any one guy to learn.. Thats why forums like this are great. You can get the exact procedure information and pass that on to the tech doing the work...
rob13572468 is offline
post #5 of 25 (permalink) Old 03-16-2008, 12:37 AM
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320
Send a message via MSN to Mr. Pie
I or I should say the tech had some problems with my wife's car recently, but it turned out to be a short in the communications system. The good news it was caught and repaired under warranty, the bad news, my wife was without her car for a week.
This issue had everyone stumped that even a master tech from Cali couldn't figure it out. The guy here ended up tracing the wires to the trunk and found that one of the harnesses was getting an intermitent connection. All the work done would have cost close to $2,000.00 in repairs but was covered as I said.
End result is that it is working now and while her car was in the shop she got to drive around in a 2008 C300.
Anyway, maybe there is a short somewhere as well. Just a thought.
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
Mr. Pie is offline
post #6 of 25 (permalink) Old 03-16-2008, 12:38 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
What did you exactly ask the tech to do? We do not have this option in Europe but I thought you would have to code the IC (phone present from optional equipment) and the Tele-Aid CTEL( MHI) fitted?
Diesel Benz is offline
post #7 of 25 (permalink) Old 03-16-2008, 06:50 AM
Quoted: 47 Post(s)
Yes, from your description the setting for "Phone present" was not made.
My understanding is that the puck with tail takes the place of the phone and there should be no reference to Bluetooth in the SDS Star programing.
It is just that simple "phone present" is all that need be changed.
They will "get it", and you will love it. Once it is working make a call before you leave the dealership to a friend so that you can asses the sound quality, call someone with a good ear.
Once that is done if the audio out quality (your microphone) is poor they have updated a module to improve the sound of your out going signal.
I will try to find the posts.
Here is the DTB P-B-82.70/3386 and the part number # A 211 82 0 3185
post #8 of 25 (permalink) Old 03-16-2008, 08:45 AM Thread Starter
jamsong's Avatar
What is "code the IC (phone present from optional equipment)"?
Is that in th Star Diagnosis?
I gave the service advisor a printout of the attached file.
Name:	e320 cell phone coding.jpg
rivera2j likes this.
jamsong is offline
post #9 of 25 (permalink) Old 03-16-2008, 09:05 AM Thread Starter
jamsong's Avatar
Great advice about calling someone - I actually did mention DTB 82.70/3386 and they ordered the part and will replace the microphone later. The post that alerted me to this was:
Bluetooth - Microphone quality - MBWorld.org Forums
On a side note, I got my SBC "dampened" along with the Puck version coding. The difference on the SBC is amazing, the sound and vibration are gone (and I'm sensitive to those things).
I'll let you all know my final outcome of my "Puck with Tail" challenge.
jamsong is offline
post #10 of 25 (permalink) Old 03-18-2008, 10:16 PM Thread Starter
jamsong's Avatar
Yacht Master, you were absolutely correct. Thanks for the definitive answer to go back to the dealer and make them do the coding correct.ly They didn't charge me for the recoding and, yes maybe they should have payed me for training their technicians on properly coding the Puck with Tail.
I reiterated to the SA what I wanted and this time around, they did exactly what I asked. I was again not present when they did the coding. I dropped the car off in the morning and picked it up in the afternoon. I got into my car, and the Comand screen immediately said "Activating Phone." Phone now works on the Comand, steering wheel controls work, and voice quality is great. After a minute, my phonebook downloaded (I have a Samsung Blackjack with WM6) and I later paired my wife's Motorola RAZR v3 and it also downloaded her address book. Wife wasn't convinced that this was worth ~$500 for the part & coding but hey, sure beats $2k, and it's worth it to me. It's such a clean install and the interface integration with the car is slick.
jamsong is offline
    2004 E55 IPhone bluetooth puck with tail works! Yacht Master W211 E55 AMG, E63 AMG 23 10-10-2014 01:48 PM
    LED tail light "Lamp out" warning display peter_02AMG W210 E50 AMG, E55 AMG 5 11-28-2010 08:32 PM
    Version 1 "Quick" Reply Button Doesn't do anything. Digmenow Benzworld Site issues forum 5 11-11-2007 03:33 PM
    SLK 200 "Final Version" for sale: €48.000 Max R170 SLK-Class 0 09-12-2003 07:46 AM
