Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 03-11-2008, 11:45 PM   #1 (permalink)
Date registered: Mar 2008
Post Timing Chain or Timing Belt?
Hey all, this is my first post! Love the site...
Does anyone know if my 1999 E430 Sport has a timing belt or timing chain?
Thanks in advance!
innaadrian2007 is offline   Reply With Quote
Old 03-11-2008, 11:56 PM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
If the car has a star somewhere, it should be a Mercedes and it would have a chain instead of a belt (I'm not sure actually if a timing belt had been used on some engines but I'm not aware of any, this one would have a chain anyway).
The chain too needs to be serviced although it would accept a lot more miles.
By the way, this one must be a W210 car.
Diesel Benz is offline   Reply With Quote
Old 03-12-2008, 12:20 AM   #3 (permalink)
Thanks for the info. So what kind of maintenance should I be doing on the chain?
Old 03-12-2008, 02:06 AM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
unless you are having problems, the chain doesnt need to be replaced. only time i have seen a need for the chain to be replaced is the chain having slack causing rough idle issues and or noises.
Streetglower is offline   Reply With Quote
Old 03-12-2008, 05:45 AM   #5 (permalink)
Date registered: Mar 2007
Vehicle: 2006 CLK 350
CHAIN
TIMING CHAINS GET REPALCED AT 100,000 MILES
tech145 is offline   Reply With Quote
Old 03-12-2008, 06:42 AM   #6 (permalink)
drivbiwire's Avatar
Date registered: Mar 2006
Vehicle: 2006 E320 CDI
Only if you have been using unapproved oils and indicate excessive mis-alignment of the cam to crank timing...
Timing chains should be inspected at regular intervals. The newer engines off the top of my head are checked at or around 140,000 miles (W211).
DB
drivbiwire is offline   Reply With Quote
Old 03-12-2008, 07:07 AM   #7 (permalink)
I realised I was using a misleading word. Inspection would have been right like the experts above stated. Then of course if at some point the inspection shows that service is needed, the chain and relevant parts are replaced with new.
Streetglover is experienced enough to inspect the car by listening to the engine sound.
Old 03-13-2008, 10:29 AM   #8 (permalink)
Vehicle: ML500, E320 4Matic
Normally if the car is maintained as suggested by MB the chains last until engine overhaul, at which time they should be replaced.
sosh is offline   Reply With Quote
Old 03-13-2008, 12:54 PM   #9 (permalink)
Not so sure, like those single row chain W140 engines, but I don't see the connection to the sentence you quoted. One would still need to inspect the chain to be sure the car has been properly maintained and no service for the chain is needed?
Timing Chain or Timing Belt innaadrian2007 W210 E-Class 3 03-12-2008 06:53 PM
E55 timing belt or chain? SarahV W210 E50 AMG, E55 AMG 6 02-29-2008 09:43 PM
230E timing belt or timing chain? DieselKraut22 W123 E,CE,D,CD,TD,TE Class 19 06-20-2007 05:26 PM
Timing Belt or Chain dimon1980 W163 M-Class 2 10-09-2006 09:49 PM
Timing Chain or Timing Belt on 230 Kompressor ? Bal W208 CLK Class 0 11-21-2005 01:08 PM
