Radio not working - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 01-23-2008, 10:58 PM Thread Starter
Date registered: Apr 2007
Radio not working
I have a e320 2003 and the radio unit doesn't work anymore i thought the display (lcd) was gone . So i when to Mercedes an bought a new head control unit radio for the car and had them replace the old unit.... now the lcd turns on and it has a Mercedes sign(logo) then turns off....i cant play cd's or even listen to the radio....the cd changer will not open...... what can i do?
all fuses work fine,
ma~benz is offline
post #2 of 16 (permalink) Old 01-23-2008, 11:09 PM
no clue's Avatar
Date registered: Apr 2006
Have you update the AGW firmware? Check w/ your service advisor for recall/Service record.
Chances are your old unit is still good.
For the "old trick" you could try....
1. power off your command unit.
2. full reset your command to factory default (on your display cluster)
3. remove the key.
4. go to your trunk and remove #6 fuse out for 2 min.
5. put the #6 fuse back in.
6. turn your key to position one. (wait for 15 seconds)
7. power on your command unit.
I drive? Nothing to brag about, just something depreciate..
no clue is offline
post #3 of 16 (permalink) Old 01-23-2008, 11:16 PM Thread Starter
i dont have my old unit MB replaced it with a brand new one... and on the new one , the display cluster doesnt do anything at all ... it just powers up u see the MB logo then it turns off and you cant do anything after that
ma~benz is offline
post #4 of 16 (permalink) Old 01-23-2008, 11:22 PM
no clue's Avatar
I understand, try the "old trick" and let's hope it works.
If not, go to your service advisor and see if following has been done.
AF82.85-P-6000P about Comand issues and a SW update. AF82.85-P_6060A about the audio gateway, reflash or replace depending on the unit. A few later updates too (probably replacing some of the older updates).
no clue is offline
post #5 of 16 (permalink) Old 01-24-2008, 03:04 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
did you have your issue diagnosed or just asked the dealer to replace your radio? if you had a new one installed and it still does the same thing, its not a software issue. have it diagnosed properly.
Streetglower is offline
post #6 of 16 (permalink) Old 01-24-2008, 04:40 PM Thread Starter
I did all what you said but it didn't work, i when to MB dealership and they said "oh its teleaid, that has malfunction...you have to pay $2k to have the new digital teleaid system then you radio will work !! i don't believe that one sec b/c there is thousands of eclass on the road that have an analogue system and their radio still works
ma~benz is offline
post #7 of 16 (permalink) Old 01-24-2008, 05:29 PM
no clue's Avatar
Go to other dealer and ask for second opinion.
Or have same guy write down the require work on paper.
Fax it to MBUSA for discussion.
My tele-aid doesn't even work, and occasionally will pop-up (tele-aid malfunction) if I accidentally press the button in the arm rest. (NOPE, I did not have digital - tele- aid, nor subscribe to it) But my radio has no problem, what-so-ever.
no clue is offline
post #8 of 16 (permalink) Old 01-24-2008, 11:00 PM
tashakes's Avatar
Vehicle: '03 E500
Its the AGW, see MBWorld.org Forums - View Single Post - Radio not working
2003 (late build) E500, TSW Estoril 19x8 & 19x9.5, 245/35/19 & 275/30/19, Lowered via Wash-o-matic, Tint, Euro COMAND + Navigation, LED Tails....
tashakes is offline
post #9 of 16 (permalink) Old 02-04-2008, 11:00 AM
Date registered: Nov 2007
Vehicle: 2003 E500
Quoted: 2 Post(s)
I want to thank the post by no-clue earlier on the reset of the command unit. My CD changer stopped working and I was going to take it to MB. I tried the reset method "old trick" and it worked. My CD changer powered up and is working fine. Thanks again this post has saved me money.
Bwbigdog is offline
post #10 of 16 (permalink) Old 02-05-2008, 06:33 AM
Bimbis's Avatar
Date registered: Dec 2006
Vehicle: Formerly a 1990 200E; then a 2003 E320; and now a 2010 E350 P1, P2, Wheel pkg & folding rear seats
On a similar note, I found that the lcd on my APS 50 radio has a number of white lines going across at the top almost totally hiding the first lines of text and a number of the buttons don't work - the lowest soft button on the left and one of the seek buttons. Has anyone experienced this before?
Any fix ideas?
Bimbis is offline
  • Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
    Radio not working vpvictoria General Mercedes-Benz 10 09-25-2007 06:46 PM
    radio not working (not the stock radio, though) numitor R170 SLK-Class 2 07-10-2007 06:22 PM
    Radio not working tabby88 Audio & Telematics Forum 1 04-15-2007 04:44 AM
    Radio not working sbhanks W123 E,CE,D,CD,TD,TE Class 5 07-20-2006 05:34 PM
    Radio not working Bradk W124 E,CE,D,TD Class 4 09-22-2005 07:38 AM
