E270 CDI performance problems - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-30-2007, 12:09 AM Thread Starter
gka
Date registered: Jan 2005
Hi There
When traveling with revs below 1800 the car is dead and as soon as the revs go beyond 1800 you can year that slight diesel knock the engine makes and then it pulls off like it should do.
What could be the problem?
The other thing I noticed is when the car is started when it is cold it used to have a loud diesel knock and as soon as it is hot the engine runs softer. Now the engine sound the same when ever it is cold or hot. Don't know what it means.
Another problem the car is extremely heavy on fuel.
Any help, suggestions will be appreciated.
Thanks
gka
gka is offline
post #2 of 11 (permalink) Old 11-30-2007, 03:38 AM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Don't know really but the CDI idle noise gets reduced from multiple injections per power stroke. A friend of mine told his CDI had a problem with the pressure sensor at the high pressure rail, if you take the wire off from the sensor, the system would not regulate the pressure down but would work at max injection pressure. This again resulting to a single injection as it would otherwise inject too much diesel when running idle. I never checked if a car like yours would behave the same way. I assume this would need star diagnosis or some special equipment anyway to diagnose and fix. Something related could be the cause for the diesel noise but the rest should be unrelated.
Diesel Benz is offline
post #3 of 11 (permalink) Old 12-01-2007, 05:22 AM Thread Starter
gka
The car was on the star system but nothing could be found.
There is clearly a problem with the car but the dealer can't find anything wrong.
gka is offline
post #4 of 11 (permalink) Old 12-01-2007, 06:57 AM
Quoted: 40 Post(s)
That is unfortunate, I wonder if engine experts here would be able to point for further diagnosis.
Could it still be an injector issue even if no error codes existed? I thought the CDI control unit would give a fault code if the injection isn't as expected.
post #5 of 11 (permalink) Old 07-11-2009, 01:32 AM
Date registered: Mar 2009
Hi There
Thanks
gka
check your catylitic converter muffler it may be partially blocked
COLIN BALES is offline
post #6 of 11 (permalink) Old 06-27-2011, 05:32 AM
Date registered: Jun 2011
loss of power when going up hill what could be the potential problem is it MAF or MAS sensor?
capricornuk2002 is offline
post #7 of 11 (permalink) Old 06-27-2011, 05:50 AM
Mercedes 270 cdi avantgarde -loss of power when going up hill
Last night when i was driving on the motorway the car did 80 miles an hour but when i was going up hill the power dropped to 40 miles an hour and it has happened twice on hilly road, what could be the potential porblem. the car runs fine on level road the problem only occurs when i am going up hill. It is a automatic car. I was reading about MAF and MAS sensors but not sure which one potentially causing the problem.i would be grateful for your assistance
post #8 of 11 (permalink) Old 06-27-2011, 09:57 AM
Date registered: Aug 2009
Vehicle: None right now
Quoted: 4 Post(s)
Replace the fuel filter and see if things improve. Most loss of power issues on diesels is due to fuel starvation caused by a dirty filter.
Pete '06 E320 CDI is offline
post #9 of 11 (permalink) Old 06-27-2011, 10:11 AM
Date registered: Feb 2008
Vehicle: 2006 E320 CDI
You say it heavy on fuel, diesel knock all the time and low power at low RPMs.
You may have an injector problem. Is the car smoking under normal acceleration?
If it were a plugged fuel filter is would be starved and most likely not heavy on fuel.
You will probably need to put it on SDS and see if it can tell what the problem is.
edwinwalke is offline
post #10 of 11 (permalink) Old 06-28-2011, 09:08 AM
I called AA their computer could not detect anything then they took me to a mercedes specialist garage and their computer showed fault with Air Pressure sensor also called charge pressure sensor. So far its good and but the problem persists then it could be MAF Mass Airflow Sensor as i have been told.
Thanks Pete for your reply!
regards
Tony
Need Help: E270 CDI Turbo Problem gka W211 E-Class 19 04-30-2015 05:55 AM
K40 Relay on E270 CDI Italian Stallion General Mercedes-Benz 2 11-24-2007 01:37 PM
E270 CDI Power Output the director W211 E-Class 0 02-11-2007 11:39 AM
Just got my Euro spec E270 CDI Avantgarde bqlsanto W211 E-Class 1 01-27-2004 10:56 AM
New E500!!! IS it true about the E270 CDI? Guest (MBNZ) General Mercedes-Benz 0 04-30-2002 04:37 PM
