2004 e320 oil change - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-19-2007, 10:42 AM Thread Starter
Date registered: Mar 2007
My computer is telling me to add one litre of oil at next refueling. I'm approx 5,000 km away from my next FFS service. What oil should I use and would the dealer do it for me. Also this is the second time it's come up in about 6,000kms. Is that normal? The first time I just put in castrol 10w30, but I understand I should be using synthetic.
Pete320 is offline
post #2 of 6 (permalink) Old 03-19-2007, 12:47 PM
Date registered: Jun 2005
Vehicle: 2003 E320 - wife's car now; 07 Porsche Boxster S - my car!!
Pete,
Here are MB's recommended oils: Mercedes-Benz Engine Oil Recommendations.
The factory fill is Mobil 1 0W-40, and when adding oil, you should use the same type. Do not use non-synthetic oil in your car at any time.
The dealer can add the oil for you, but I don't know if they would charge you. The MY04 in the US still had the free maintenance while car is under warranty.
My 03 E320 has 119km and it doesn't burn any oil. Is your E320 burning oil or does it have a leak somewhere?
Regards,
paul...
paulv is offline
post #3 of 6 (permalink) Old 03-19-2007, 03:12 PM
drivbiwire's Avatar
Date registered: Mar 2006
Vehicle: 2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
Why in the world would you put in Castrol 10w30?
I would STRONGLY suggest reading your owners manual ASAP!
The FFS oil change interval thanks to you using the Castrol is NO LONGER VALID and CANNOT BE RELIED UPON!!! The fact you used an oil that is NOT approved for use in your engine negated the data that is stored to determine the proper oil change interval.
Instead of waiting 5000km, take it in for an early oil change and from this point on USE THE CORRECT OILS ONLY!
DB
drivbiwire is offline
post #4 of 6 (permalink) Old 03-19-2007, 11:51 PM
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
DB used strong words...and he 's right! Particularly having added regular oil to the synthetic already in the engine: get it changed asap.
Your oil usage is not excessive but would not hurt for them to check for any leakage.
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline
post #5 of 6 (permalink) Old 03-20-2007, 07:49 AM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
Pete; thats unusual for a few years old model.
If you are using Dinosaur Oil please do not use it.
MB Owners Manual calls for Full Synthetic.
If your confused as to what brand to use, ie: Mobil1, Castrol, Amsoil, Valvoline, then stay with the one MB uses, Mobil 1 Full Synthetic 0W40
Is that right guys?
If I was in your shoes, and I have been, I would go do it myself. Because you see; I trust myself more than anyone I know
Recommend you get Mobil 1 Full Synthetic & New Stealership Oil Filter
If your not comfortable doing it yourself then get the Stealership to do it for you.
Don't wait any longer.
Look; your car is not going to die using Dinosaur Oil, but IT WON'T HELP!
You have a fine vehicle. Keep it running good with the good stuff.
Good Luck!
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #6 of 6 (permalink) Old 03-20-2007, 09:51 PM
drivbiwire's Avatar
Just keep it simple, make sure regardless of what oil you use that it has on the label "MB 229.5" or "MB 229.51" thats all you need to know in term of assurance that it will protect your motor.
DB
    Just bought 2002 E320, 51,000 miles, some questions about oil change josetann W210 E-Class 14 10-06-2006 11:49 AM
    How often should I change the oil on my 05 E320 CDI? stlpete W211 E-Class 4 12-16-2005 04:30 PM
    99 E320 Change Oil "Reset" Boman49 General Mercedes-Benz 1 04-16-2005 06:24 AM
    1999 E320 oil change question woodnut W210 E-Class 11 09-23-2004 10:13 PM
    2001 E320 First Oil Change Guest (MBNZ) W210 E-Class 2 07-30-2002 05:06 PM
