Yes One CAN Install the AMG Eight Piston calipers with the larger Rotors on the front and the Four Piston Calipers with larger rotors on a W211 E350...I Did on the Wifes 2006 W211 E350
You will Need at least 18s to clear the rotors
AMG also make the 030 Extra large front Brakes..Then You WILL Need 19s
And Yes Brembo makes big brake kits for the W211
as Brembo makes the calipers for AMG
i knew they made the calipers for amg but i dont want stock e55 calipers since i found outy they have ebc, does that matter considering you put them on your wife's ride? and would you happen to know where i can find the brembo kit with pricing because i can't find anything except some brake kits on ebay from an australian company called g4. im soo confused. please help
