no heat - Mercedes-Benz Forum
post #1 of 40 (permalink) Old 11-15-2006, 10:32 PM Thread Starter
Date registered: Nov 2006
Vehicle: 2003 e500
no heat
i have absolutlely no heat.my blowers are working great but it feels like the ac is always on.the car blows freezing air at all temps.does anyone have any suggestions before i take this 03 e500 in for service AGAIN.please help my kids cant drive in this beauty,and thats a $40000 shame.
greek500 is offline
post #2 of 40 (permalink) Old 11-16-2006, 03:55 AM
Date registered: Sep 2006
I had the same problem. There is a faulty valve that takes a few mins to replace. My job was done under warranty
Hot E320 is offline
post #3 of 40 (permalink) Old 11-16-2006, 09:03 AM
lear31a driver's Avatar
Date registered: Jan 2006
Vehicle: 07 E63 AMG Black on Black
This is specific to the 2003 E500
Have the dealer look into this TSB:
Date: September 17, 2004
Order No.: P-B-83.20/72
Supersedes:
Group: 83
SUBJECT:
Model 211.026/065/070/076/082/083/265/270/282/283
No Warm Air in Heating Mode
Control valve lists for $36.00 and takes 1.4 hrs to install, test takes .4 hr.
07 E63 AMG ** 05 E500 ** G36 Beech Bonanza
The AMG slams the competition
The E500 keeps up with the best of them
The G36 is the fastest and hardest to parallel park!
lear31a driver is offline
post #4 of 40 (permalink) Old 11-16-2006, 05:09 PM
Date registered: Apr 2006
Where are you in KY? If near Louisville i can help you out.
Taylor
MBTECHNICIAN is offline
post #5 of 40 (permalink) Old 11-16-2006, 06:57 PM Thread Starter
Vehicle: 2003 e500
i am in northern ky,not to far from louisville.
greek500 is offline
post #6 of 40 (permalink) Old 10-17-2007, 08:32 AM
Vehicle: 03 E500
Supersedes:
Group: 83
SUBJECT:
Do you have a diagram or a picture of this valve? I need mine replaced and think I could do it myself.
bigswol2 is offline
post #7 of 40 (permalink) Old 10-17-2007, 10:42 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 215 Post(s)
Change over valve part # A2118320584 - #30 in diagram. The valve is located in the engine compartment, beneath the plastic trim below the windshield on driver’s side.
konigstiger is offline
post #8 of 40 (permalink) Old 10-21-2007, 11:03 PM
Date registered: Aug 2007
Hi konigstiger,
I'm trying to replace a valve myself. Is there any precaution I should be aware of before the installation? Thanks!
newman415 is offline
post #9 of 40 (permalink) Old 10-23-2007, 07:25 AM
vettdvr's Avatar
Date registered: Mar 2007
Vehicle: E500
Originally Posted by newman415 View Post
Hi konigstiger,
USE EXTREME CAUTION removing from the heater core so you don't crack a joint. Don't twist or pull excessively where it attaches to the core.
Good judgment comes from bad experience. Now want to know how to change a heater core in a Corvette.
vettdvr is offline
post #10 of 40 (permalink) Old 10-26-2007, 03:45 PM
Thanks for the help! Other than carefully removal, is there any thing I should be paying attention? Is the water going to leak out of the heater core or other place?
    I'm sure the Heat has something to do with this..... mclasser W163 M-Class 1 06-05-2006 11:18 AM
    Heat -oh lovelly heat! alaskagwagen G-Class 11 02-11-2006 07:24 AM
    The heat is on!!!! deathrattle Off-Topic 35 10-27-2005 08:50 AM
    No heat. theoskyhigh W201 190-Class 1 05-05-2005 07:13 PM
    HEAT! HEAT! HEAT or absence thereof... barry_s_u W126 S,SE,SEC,SEL,SD,SDL Class 8 01-18-2004 08:55 AM
