» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 10-03-2006, 11:21 PM   #1 (permalink)
RNBRAD
Date registered: Jun 2006
W211 Rear door panel removal?
On a 2004 E320, I need to remove the rear door panel and thought I would check here and see if anyone can tell me where the screws/attachments are at? Thanks.
RNBRAD is offline   Reply With Quote
Old 10-04-2006, 02:57 PM   #2 (permalink)
lkchris
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
It's in various pieces.
For example, the top cap is a separate part.
It's covered in several documents in the workshop manual, now available from Mercedes for ~$60.
There's an airbag there, meaning you must disconnect your battery when messing with the door panel.
This means you need mercedes special tool help to recover from disconnected battery.
You should really want to attempt this.
Kent Christensen
Albuquerque
Old 10-05-2006, 07:25 PM   #3 (permalink)
RNBRAD
I really just need to remove the top cap. Also you can disconnect the airbag as long as you don't turn the ignition key on while it is unplugged. Then you will get an airbag malfunction warning and need a reset.
rear door panel removal? imwalkin W163 M-Class 2 06-23-2005 02:42 PM
Rear Door panel Removal SethMac86 W124 E,CE,D,TD Class 7 04-10-2005 01:58 PM
Rear Door Panel Removal 1998 adl727 W210 E-Class 2 09-07-2004 06:15 AM
Removal of Rear door panel on 99 S500 Joey6 W140 S-Class 1 08-16-2003 06:17 AM
Rear door panel removal? ChristopherGeorge G-Class 2 12-13-2002 01:08 PM
