» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W211 E-Class
Old 09-03-2006, 03:54 PM   #1 (permalink)
Date registered: Dec 2004
Vehicle: 2003 E320
03 E320 Bluetooth problem
Hey everyone
Just installed MB v60 phone kit in my 03 E320; also installed MB v60 Bluetooth adapter. The problem is that after successfully pairing Razr cell phone with the adapter, the radio will read “phone not installed” and I can’t make any calls from the radio and I can’t answer any incoming calls. But if I make a call using the Razr, the radio will mute, and I can speak and hear via the hands free system; can also view the phone book. After all calls have ended, it’s back to “phone not installed” same thing happens for incoming calls. I can hear the incoming calls ringing through the car speakers, but to answer the call, I have to use the cell phone, and then the call is transferred to the hands free system. Its like incoming and outgoing calls have to be initiated with the cell phone and then via hands free system.
nyclad is offline   Reply With Quote
Old 09-10-2006, 10:26 AM   #2 (permalink)
Vehicle: 2003 E320
Well, fixed the problem I was having with the Bluetooth and hands free system. When I took it to the dealer last week they were pretty much stumped by what was going on. One service rep even claimed that the Bluetooth adapter might be the problem being that Mercedes doesn’t make a Bluetooth adapter for the V60 cradle. Needless to say he felt kind of stupid when I told him that I bought the adapter at his dealership from his parts department. Anyway, they kept the car for the day, but to no avail. Checked version coding, checked all related components, even put a V60 phone in the cradle but Audio 50 still would no recognize the phone. So they came to the conclusion that it was a defective cradle; changed the cradle same problem. So I did some research using the MB WIS CD and found a possible solution to my problem. Software update! Went back to the dealer updated AGW to the latest software also rechecked version coding. Phone still didn’t work. So I went home got my MB V600 phone, managed to make a connection with the V60 cradle, and the phone worked everything worked. Reinserted the Bluetooth adapter, no problems everything works as it’s supposed to. I can now view the phone book, dial and receive calls using Audio 50 and my RAZR.
Old 09-13-2006, 09:11 AM   #3 (permalink)
Dallas_E500's Avatar
Date registered: Feb 2006
Vehicle: 04 E500
Could you tell me all the parts you you need to get for this to work. In the process of ordering my Razr phone. Would like the grocery list of products I need to search\buy.
Also do I need to have a v60 1st to make the connection or can I use a new Razr, and will it work with the Bluetooth adapter.
Dallas_E500 is offline   Reply With Quote
Old 09-13-2006, 08:01 PM   #4 (permalink)
Vehicle: 2003 E320
Hey Dallas_E500
You’re going to need the V60 cradle short coil-cord # Q6820833 or Q6820899 Compensator # Q6820832 which I got used on eBay.
No, you shouldn’t need a V60 phone, the Bluetooth adapter and the Razr should work fine. You may also need version coding and maybe software update for the Audio Gateway (AGW) at the dealer. I have the MB phone installation instructions for 2003-2004 E Class if you want, let me know.
Old 09-14-2006, 09:31 AM   #5 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
Originally Posted by nyclad
Hey Dallas_E500
Just a question: Why would the compensator be needed if the intention is only to use the BT puck? I understand that a complete set needs this to enable a cradle connection. Also Steve has mentioned that the compensator can be left out even for the basic installation (done that for retrofit installations). I can imagine this can have marginal loss for 1900 MHz operation but no real loss for 850 MHz, if you just bypass the compensator.
Diesel Benz is offline   Reply With Quote
Old 09-14-2006, 04:35 PM   #6 (permalink)
Vehicle: 04 E500
Hey Dallas_E500
So all I need is 2 parts: either # Q6820833 or Q6820899 and then the Q6820832. Are all these parts avaible on ebay?
Would the dealer do the SW update if requested or do I need to be specific.
Would really appreciate it if you could send me the install guide.
Regards,
TS
Old 09-16-2006, 12:17 PM   #7 (permalink)
Vehicle: 2003 E320
Hey Dallas_E500
“The compensator is used to "compensate" for the small amount of power that is lost as a result of the extra RF cable needed to send or receive the signal through the vehicles antenna. The compensator is not a booster when in digital or analog modes”
MERCEDES BENZ TELEPHONE MANUAL
Diesel Benz is probable right about the compensator; you might not need it being that you’re using the Bluetooth adapter which doesn’t have a connection for the antenna. I would get only the cradle from the dealer or eBay if you can find it, version code, and ask the dealer to check and update the AGW if needed. You also want to get the Holder # Q 682 0768 which is screwed down inside the armrest and then the cradle sits in the holder
Old 03-17-2007, 11:18 PM   #8 (permalink)
Date registered: Dec 2006
Hey Dallas_E500
What is the differnce between the V60 cradle short coil-cord # Q6820833 or Q6820899 and the Q6820724?
benltc is offline   Reply With Quote
Old 07-24-2007, 01:42 PM   #9 (permalink)
Date registered: Jul 2007
Phones parts
Hi,
I have 2003 E320 W211 with Teleaid and no phone
1. Are these the parts that are needed or do I need anything else?
2. What is the part number for blue tooth ?
Part Number: Q6820768 V60 HOLDER
Part Number: Q6820833 W211 V60 CRA
Part Number: Q6820832 W211 CABLE,
khanasa is offline   Reply With Quote
Old 10-14-2007, 02:48 PM   #10 (permalink)
Send a message via MSN to cyberbloke
I have S600 2001. It has Motorola TimePort (Silver). I want to upgrade to bluetooth, what parts do I need. Just a short coil cradle for V60 and compensator or do I need to get something different. Thanks in advance.
cyberbloke is offline   Reply With Quote
Bluetooth Phone on a 2000 E320 (Fiber) harb W210 E-Class 5 09-21-2007 02:49 PM
03 E320 Bluetooth problem nyclad Audio & Telematics Forum 1 09-10-2006 10:27 AM
Bluetooth Tero 650 on a E320 Vasa Audio & Telematics Forum 0 07-01-2005 06:22 AM
04 E320 AC problem tyltan General Mercedes-Benz 0 05-17-2005 12:04 PM
Please Help! I have a problem with a E320! eurodriver W124 E,CE,D,TD Class 10 07-01-2003 12:07 AM
