Removing overhead console, lessons learned - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-03-2005, 06:21 PM Thread Starter
fgwinn's Avatar
Vehicle: SL550
I had intended to remove the overhead console in order to tap into an ignition switched power source for a windshield mounted Garmin c340 GPS unit. I managed to remove the console without breaking any plastic parts but I did damage a couple of things. Fortunately I was able to recover without a visit to the dealer.
After an unsuccessful attempt to identify an ignition switched power source, I ended up giving up and picking up power from the lighter socket in the ashtray.
Just in case anyone needs to remove the console to replace a light bulb, here are the basic steps.
1) Unsnap the cover around the stem of the mirror.
2) Disengage the retainer from this cover in order to completely remove the cover to allow access to the remote clip disengagement buttons (not sure what these are really called).
3) There are two black "buttons" on either side of opening around the mirror stem. Press in slightly while pulling down on the front edge of the console.
4) Pull down the rear edge of the console but be careful not to damage any cables. There are a lot of cables attached to the console. If you disconnect the cables, I recommend taking several digital pictures first to use as a reference. The cable ends are color coded to the various sockets.
When re-installing the console I found that it is easier to start by putting the front edge in place first then push up the back edge.
The plastic cover in front of the console that covers the rain sensor can be removed by applying steady downward pressure on both sides, one side at a time. It's not easy to remove but it's possible.
I managed to tear the ribbon cable runing from the console to the rain sensor. One of the three leads was severed. I scraped off a small amount of insulation on each side of the tear and soldered a "jumper" across the break. I wrapped some electrical tape around the repair. Seems to work okay. I will price a new cable and replace it if I ever need to deal with a warranty repair in the console.
I also managed to screw up the sun roof by probing around with a volt meter and ohm meter. Messing up the sun roof was the thing that convinced me to give up on tapping into the power in the overhead console. It's relatively easy to tap into the lighter power plug and run the cable to the lower corner of the windshield on the driver side (US model).
After exploring the various power sources in the overhead console, the sun roof behaved very oddly. I lost the express open/close feature and the sunroof would only move an inch or so at a time in either direction. Up and down movement did not correspond with the up and down motion of the switch in the console. I was fully expecting to be facing a $500+ repair bill.
I decided to verify that the relevant fuses were not blown before visiting the dealer and trying to explain what happened. The sunroof and just about everything else in the console is run through fuse 009 in the trunk (9th position starting from floor of trunk. I removed the fuse and confirmed that it was NOT blown. I verified that this was the correct fuse by confirming nothing in the console worked when it was removed. However I did note that the SOS light still lit when starting the car.
I was very fortunate. Removing the fuse apparently reset the sunroof system. It now works normally.
Recommendation: Don't fool around with the circuits in the overhead console.
fgwinn is offline
post #2 of 10 (permalink) Old 10-03-2005, 11:11 PM
Date registered: Jun 2004
Vehicle: 2005 E55
RE: Removing overhead console, lessons learned
Boy, glad there was no serious harm done. Here's some pics for tapping the switched 12v for the cigarette lighter fgwinn mentioned.
http://mbworld.org/forums/showthread...hlight=install
xraydoc is offline
post #3 of 10 (permalink) Old 10-03-2005, 11:31 PM
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
Who .... why ....
There are 3 fuse boxes in the car. Would it be so bad if you just posted a Q and found a switched supply in the fuse box.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline
post #4 of 10 (permalink) Old 10-04-2005, 04:03 AM Thread Starter
fgwinn's Avatar
Vehicle: SL550
Good point. But I also wanted to check out the console setup to explore the feasibility of and options for mounting an aftermarket phone kit microphone. Plus it seemed like the shortest distance to pick up power for a windshield mounted radar detector.
Do you have any photos describing a fuse box power tap?
miroj - 10/4/2005 2:31 AM
Who .... why ....
fgwinn is offline
post #5 of 10 (permalink) Old 10-04-2005, 06:41 PM
Vehicle: 2005 E55
miroj- I researched this a lot when I wanted to hardwire my radar detector. Several, including Scorchie, say the problem with the fuse box is that true 12v is hard to find in the W211. Voltages are all strange numbers like 6.3. The easiest place to get switched 12v is from the lighter.
xraydoc is offline
post #6 of 10 (permalink) Old 10-08-2005, 06:18 AM Thread Starter
fgwinn's Avatar
Vehicle: SL550
Overhead console photos
For anyone still not convinced that tapping into a circuit in the overhead console is not worth the effort, here are a few photos. BTW, the ribbon cable that I damaged for the rain sensor was only $9.25 to replace, so, I ordered a new one. The first photo is of the cover that snaps over the rain sensor.
fgwinn is offline
post #7 of 10 (permalink) Old 10-08-2005, 06:25 AM Thread Starter
fgwinn's Avatar
Vehicle: SL550
Second attempt at photos...
Apparently the photos got lost when I edited the post. Here they are again.
fgwinn is offline
post #8 of 10 (permalink) Old 02-07-2010, 03:38 PM
Date registered: Aug 2009
Vehicle: 2005 E320 CDI, 1992 300TE, 1999 Porsche 911 Cabriolet
Post SOS light comes on everytime.
Was there ever a fix for the SOS light coming on? I tapped into something in the overhead console and now my SOS light comes on.
I also opened up the rear overhead light to insert some foam to stop a squeek and now it doesn't light up anymore. What gives?
I wouldn't have messed with the rear light if it didn't squeek.
Peter
ptkacik is offline
post #9 of 10 (permalink) Old 02-08-2010, 09:57 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Which WIS intructions did you reference during this effort?
Do "your" instructions parallel WIS? How do they differ?
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #10 of 10 (permalink) Old 03-31-2015, 10:39 AM
Date registered: Aug 2007
Vehicle: 2011 GL 320 CDI, 2004 E320, 2000 C230, 2004 Toyota Sienna
Quoted: 5 Post(s)
Rain sensor ribbon
I also damaged the rain sensor ribbon. Can you please tell me the part number and where you ordered it from ? Thanks
frobi is offline
