If many of you don't look inside where your spare tire is, you may miss the leak that I have on mine. It goes below the plastic that holds the spare tire and onto the painted shelf surrounding it. You wouldn't know its leaking if you only open the trunk normally. I have it at the dealer and they are subbing it out to a body shop.
I'm also having the front lower control arms replaced since it has that steering wheel shimmy between 60 and 65 mph. Thanks to this forum, I knew there was an internal repair memo on this from Mercedes as far as I know.
The car has 39,000 miles on it and needs new tires soon. Its been great!
