Clock Setting - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-23-2005, 08:20 AM Thread Starter
RSBSLK55's Avatar
Date registered: May 2005
Vehicle: SLK55
Clock Setting
Hi Folks - I am waiting for a SLK 55 on hold at VPC in Baltimore. The dealer was nice enough to loan me a E350. How do I set the clock? Never owning a Merc before, I have no idea. There's no manual in the car and I called the dealer for instructions and was told to bring it in, it's too complicated. Not wanting to make the trip, I thought I'd ask here.
Rob in Ct
RSBSLK55 is offline
post #2 of 10 (permalink) Old 07-23-2005, 11:40 AM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 116 Post(s)
RE: Clock Setting
http://waltermitty.net/mb/2002%20ste...%20buttons.pdf
i dont have one for E350 but hoping that the above 2002
sequence might get you closer to the solution.
raymond-
47║34'N 122║18'W
raymond- is offline
post #3 of 10 (permalink) Old 07-23-2005, 06:57 PM Thread Starter
RSBSLK55's Avatar
Vehicle: SLK55
RE: Clock Setting
Thanks Raymond for the post but it didn't work. The clock is not the same. It's a standard clock with hands. I would think the little knob next to it would do it, but it doesn't seem to turn.
Rob
RSBSLK55 is offline
post #4 of 10 (permalink) Old 07-23-2005, 08:15 PM
raymond-'s Avatar
Vehicle: 99 E320
Quoted: 116 Post(s)
RE: Clock Setting
Hmm, got me. How about pulling or pushing the knob
while turning?
raymond-
47║34'N 122║18'W
raymond- is offline
post #5 of 10 (permalink) Old 07-23-2005, 09:25 PM Thread Starter
RSBSLK55's Avatar
Vehicle: SLK55
RE: Clock Setting
Nope.
Rob
RSBSLK55 is offline
post #6 of 10 (permalink) Old 07-24-2005, 08:43 AM
X72
RE: Clock Setting
On my 03 W211, it is not that different from the W210 procedure that was mentioned above.
The clock is set using the buttons on the steering wheel. Use the 2 buttons that looks like 2 sheets of paper to scroll to "settings", then press either the up or down arrow. Scroll to "time/date" with the + and - button. Select time/date with the up or down arrow. Change time and date with the + and - button. Then you must press the black stalk sticking out of the instrument cluster (reset button) to confirm the change.
If your loaner has an owner's manual, I recommend you read it to give you a heads up on your new car.
William
2003 E 320
X72 is offline
post #7 of 10 (permalink) Old 07-24-2005, 09:52 AM
Rafael Grullón's Avatar
Vehicle: 1997 E420 Sport
RE: Clock Setting
It should work pushing the knob while turning. If this help let me tell you that there´s some "play" on the knob when you push and turn it before the needles move. If not then it is not working properly.
It´s posible that the gears are disaligned.
From silver star to silver star,
Rafael
Rafael Grull├â┬│n is offline
post #8 of 10 (permalink) Old 07-24-2005, 09:57 AM
RE: Clock Setting
I think I told you wrong. I thougt you were talking of a W124 not a W211.
Sorry
Rafael
post #9 of 10 (permalink) Old 07-24-2005, 03:46 PM
Vehicle: ML550, W212 E350 4 matic, 1966 Corvette C2 convt.
RE: Clock Setting
If the car has nav you set the nav time the difference from GMT and the clock should synch with that. That is if the set up on the MFD has ben done correctly.
sosh is offline
post #10 of 10 (permalink) Old 07-24-2005, 06:15 PM Thread Starter
RSBSLK55's Avatar
Vehicle: SLK55
RE: Clock Setting
Thanks William - That did it. No manual in the car.
Rob
RSBSLK55 is offline
